I am new on Ubuntu (try to switch from Windows). Now I try to run Wordfast Pro 7.2.0 on Ubuntu.
Running the programm leads to the following error:
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00007f741806b740, pid=8313, tid=8383
JRE version: OpenJDK Runtime Environment 18.9 (11.0.13+8) (build 11.0.13+8) Java VM: OpenJDK 64-Bit Server VM 18.9 (11.0.13+8, mixed mode, tiered, compressed oops, g1 gc, linux-amd64) Problematic frame: C [libX11.so.6+0x2b740] XInternAtom+0x40
I deinstalled OpenJDK and installed Oracle JDK but still receive the same error.
"java -version" gives:
Java version "17.0.5" 2022-10-18 LTS Java(TM) SE Runtime Environment (build 17.0.5+9-LTS-191) Java HotSpot(TM) 64-Bit Server VM (build 17.0.5+9-LTS-191, mixed mode, sharing)
Could you please help me to find a solution?
Risu
It is a missing library:
sudo apt install libgconf-2-4
And restart Wordfast
Artur Meinild
  • 31,035
Marc
