How do I update webcamoid 8.8.0 to the newest release (9.0.0) from the terminal on Ubuntu 22.04? I have tried sudo apt update webcamoid and it did not work.
harp
sudo apt update only updates the list of available software. You also need to run sudo apt upgrade to update your software.
However, 8.8.0 is already the most up-to-date version of this package in Ubuntu repositories, so it will not be updated at this time.
It's usually not recommended to install versions of software that are different than those in repositories. For an explanation why, see Why don't the Ubuntu repositories have the latest versions of software? In short, the versions of software in repositories are tested to work with your system. Other versions are not and may cause problems.
If you really need a newer version of the software, you'll need to obtain it from another source (usually the developer) and this will be at your own risk to your system and any collateral damage if there are incompatibilities with shared dependencies.
In this case, the developer publishes several releases as well as source code on GitHub. It looks like they offer an AppImage which is a self contained method of software distribution which is much less likely to interfere with the rest of your system. I say "less likely" because this AppImage still relies on dependencies in your system. AppImages don't need to be installed. Just download it and execute it directly.
Related reading: Are PPAs safe to add to my system...
Nmath
  • 12,664
Installing latest webcamoid from repository to Ubuntu 22.04
sudo apt-get install cmake libgl1-mesa-dev qt6-base-dev qt6-declarative-dev libqt6svg6-dev qml6-module-* qttools5-dev-tools
git clone https://github.com/webcamoid/webcamoid.git
cd webcamoid cmake -S . -B webcamoid-build BUILD_FLAGS_GOES_HERE cmake --build webcamoid-build --parallel 4 cmake --install webcamoid-build
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH webcamoid
Uninstalling
cd webcamoid-build
sudo make uninstall
sudo apt-get purge cmake libgl1-mesa-dev qt6-base-dev qt6-declarative-dev libqt6svg6-dev qml6-module-* qttools5-dev-tools
mixalbl4
  • 135
-2
'update' only retrieves the package, I do not think it upgrades/installs it. If the command you tried before is successful then I suggest running "sudo apt install webcamoid". Hope this helps
