I have issues when booting the kernel 6.0.1, here the things : I can compile the kernel, but when making update-initramfs -u (for update or -c to create) -k 6.0.1, the initramfs-tools scripts :
/usr/share/initramfs-tools/scripts/init-bottom/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/local-bottom/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/panic/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/init-top/ORDER ignored: not executable
/usr/share/initramfs-tools/scripts/local-premount/ORDER ignored: not executable
But it make it throught anyway. Grub is correctly updated. After reboot, the system correctly boot on the new kernel, but have an issue : kernel couldn't find suitable memory target. So I think that is a initramfs issue. After that, I notice that my new kernel image is far more bigger that the olds ones :
lrwxrwxrwx  1 root root   16 oct.  15 11:33 initrd.img -> initrd.img-6.0.1
-rw-r--r--  1 root root  61M sept. 15 18:25 initrd.img-5.15.0-46-generic
-rw-r--r--  1 root root  61M sept. 15 18:24 initrd.img-5.15.0-47-generic
-rw-r--r--  1 root root  61M sept. 29 18:52 initrd.img-5.15.0-48-generic
-rw-r--r--  1 root root  61M oct.  12 21:21 initrd.img-5.15.0-50-generic
-rw-r--r--  1 root root 482M oct.  16 15:06 initrd.img-6.0.1
So I reduced it with :
root@laptop:/lib/modules/6.0.1# find . -name *.ko -exec strip --strip-unneeded {} *
The image size was similar to others versions' images, and made a update-initramfs. After that, no more memory issue, the kernel ran, but failed to load modules, and entered into rescue mod. The loading-module.service was unable to start, failed because of some rights reasons, if I correctly understood..
If someone had once the same problem, or an idea to fix that, I'll appreciate it. Thanks
Doug Smythies
  • 16,146
Arthod
Many thanks for your returns. It turns out that it was the lockdown kernel parameter (when configure with make menuconfig), I set it to integrity mode, for increasing security. But it seems that parameter didn't allow the kernel to charge the modules ! It sounds strange, but I turned off the lockdown kernel, re compiled and reinstalled it, now it's work perfectly. Too bad for this security parameter.
# uname -r
6.0.1
@Artur Meinild, @Doug Smythies : Thanks again for the help, I explored yours suggestions too.
Pablo Bianchi
  • 17,371
Arthod
