The organization of hard disks and other storage media in Ubuntu (and Linux in general) is quite different than it's done in Windows. There are no drives denoted with letters like C, D, E and so forth. The E in your error message simply stands for "Error". There are also "Warnings", denoted by W, and so forth.
The error in your case is that you try to install a package called dotnet6, but apt-get can't find a package by this name. You may need to activate the repository or component that contains this package.
Packages are organized in components. Among the main components are "Main", "Universe", "Multiverse" and "Restricted". The main differences between those components are how the software in the packages is licensed and whether Canonical (the company behind Ubuntu) provides support for the packages or not.
As you can see from the description of the package dotnet6, this package is located in "universe". So you need to check whether you have activated the "universe" component. This can be done with a graphical interface from the "Software" tool, see for example here.
Or you can edit the file /etc/apt/sources.list (with root privileges). There, look for a line similar to
deb http://archive.ubuntu.com/ubuntu focal main universe restricted multiverse
and check that "universe" is included. Maybe you'll find the components on individual lines like
deb http://archive.ubuntu.com/ubuntu/ focal universe
deb http://archive.ubuntu.com/ubuntu/ focal multiverse
EDIT: I just realized that you're using an older release of Ubuntu, 20.04 Focal. The package dotnet6 isn't included in this release, it's only available since 22.04 Jammy. You either need to upgrade your installation to at least 22.04, or to get the package dotnet6 from another source.
