Attempting to install GIT using apt-get and it's failing.
All of the web searches turn up different commands none seem to work.
Output of the install command
sudo apt-get install apt-transport-https ca-certificates git curl gnupg -y
Reading package lists... Done
Building dependency tree... Done
curl is already the newest version (7.81.0-1ubuntu1.4).
gnupg is already the newest version (2.2.27-3ubuntu2.1).
gnupg set to manually installed.
ca-certificates is already the newest version (20211016).
ca-certificates set to manually installed.
git : Depends: liberror-perl but it is not installable
Note this is running in VirtualBox but I don't believe that should impact the outcome?
Any help would be greatly appreciated
karel
  • 122,292
  • 133
  • 301
  • 332
Ham C
First try to enable the multiverse repo: there should be a Software & Updates app in your app menu that has a tab called Ubuntu Software. Open it, and check if the multiverse and restricted options are checked. It should prompt you for your password when you modify them. After you're done, close the window and do sudo bash -c 'dpkg --configure -a && apt update && apt upgrade'. And with that finished try and install git again, it should work.
