I have been trying to run firefox but everytime i try to run it through the terminal commands, it shows "cannot locate base snap core20: No such file or diretory". I tried removing and reinstalling firefox as well as snap. Refreshing snap was also of no use. On Removing firefox, terminal shows "error: snap "firefox" has "refresh-snap" change in progress." Using GUI too, firefox does not turn on. Please help.
Asked
Active
Viewed 1.4k times
sudo snap disable core20
sudo snap enable core20
BTW: This condition is an inexcusable bug in snap.
James Bowery
- 667
Had to do sudo snap install core20 --beta then sudo snap refresh firefox finally sudo snap refresh core20 --stable
... then it worked for me
Anthony Etim
- 21
Use snap list to check out your core20. If the last column "Notes" shows "broken" or something like that.
Then sudo snap remove core20, then sudo snap install core20.
Then check out snap list again.
Also, you'd better check whether other core or apps have "broken" or "disable" in the "Notes" column.
You can use snap help to search for what you want.
This way helped me to repair firefox, hope it can help you.
yaoyhu
- 131
- 6
