I installed the latest version (18.2.0.2) of Viber from the .deb package provided at https://www.viber.com/en/download/
After installing the new version, I noticed that there is no way to terminate the Viber application using GUI: The "Quit" option for the application menu does nothing. As in the previous versions, closing the main window does not terminate the application (it continues to run on the background); however, contrary to previous versions, using the right-click (system) menu of the application and selecting Quit does not terminate the application.
When I ran it from command line and then tried to "quit" the application, I see this message on the terminal window:
qt.qml.context: qrc:/Resources/QML/MainWindow.qml:68:5 Parameter "close" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
To terminate Viber I have to kill it using -1.
Is there a practical way to fix this, so that Viber users do not have to resort to command line to stop (and restart) Viber whenever they need?
FedKad
  • 13,420
That's a known bug*. Something changed in Viber tray icon handling. Right click menu could be broken on KDE Plasma as well.
You can workaround it with such steps:
  1. Install dbus-x11 package (which contains CLI utility dbus-launch)
    sudo apt install dbus-x11
  2. Kill viber instances
    pkill -f -9 viber
  3. Try to launch it on a terminal with dbus-launch
    dbus-launch /opt/viber/Viber
  4. Check if right click works. It's not perfect but works from few tries
  5. Modify Viber launcher
    a) On the original Ubuntu (with GNOME) you can install menulibre package for that
    b) You can do it manually on a terminal
    sudo nano /usr/share/applications/viber.desktop
  6. Log Out and Log In
*https://github.com/flathub/com.viber.Viber/issues/4#issuecomment-1280456307
Alex
  • 178
Yevgen
  • 101
Viber version 20.3.0.1 finally works properly in Ubuntu 23.04.
The .deb package is provided at the official Viber website.
karel
  • 122,292
  • 133
  • 301
  • 332
Alex
  • 178
