How to configure file manager Krusader to copy names or full paths for selected files / directories like in Total Commander?
Related question: Shortcut to select / copy current directory in Krusader file manager
Krusader -> Useractions -> Manage User Actions...
Add two new user actions with the following configuration:
Identifier: Copy Names
Title: &Copy Names
Command: %_Clipboard("%aList("Selected", "\n", "Yes", "", "No")%")%
Shortcut: Ctrl + Alt + N
Identifier: Copy Paths
Title: &Copy Paths
Command: %_Clipboard("%aList("Selected", "\n", "", "", "No")%")%
Shortcut: Ctrl + Alt + P
Krusader -> Settings -> Configure Keyboard Shortcuts...
Remove duplicated Ctrl + Alt + P shortcut from 'Play/Pause Job' action
or user other shortcut.
To check config select several files/directories. Press Ctrl + Alt + N to copy to clipboard names, Ctrl + Alt + P to copy paths.
Description for commands config from Krusader UserActions:
List - replaced by a list of all <first parameter>
Parameter: Which items; either “All”, “Selected”, “Files” or “Dirs”
Parameter (optional): Separator between the items. Default: “ ”
Parameter (optional): Omit the current path. Default: no
Parameter (optional): Filtermask (for all but “Selected”).
Default: *
Parameter (optional): Automatic escape spaces. Default: yes
Select - manipulates the selection in a panel
Parameter: Filtermask
Parameter (optional): manipulate in which way; either “Set”,
“Add” or “Remove”. Default: “Set”
Clipboard - manipulates the clipboard
Parameter: The text that should go to the clipboard
(you may want to use “%aCurrent%” here)
Parameter (optional): Append the text to the current content
of the clipboard with this separator
Related links:
Thank you Anton!
I was so annoyed I didn't have this convenient TC shortcut in krusader. Following your instructions, in Kubuntu 24.04 I stumbled upon
Ctrl-Alt-C in Krusader -> Useractions -> Examples:
"Dateipfad des ausgewählten Eintrags kopieren (maskiert Leerzeichen)"
which translates roughly to (sorry, my Desktop is in German):
‘Copy file path of the selected entry (masks spaces)’
It was already there with the standard installation, maybe it was finally added sometime since 2022 :)
