I'm having an issue with a shared library called libsdl. What I'm trying to do actually is to start up a game engine called GCCG (Generic Collectible Card Game). All the necessary packages were installed for the engine, however when I run the command ./Mtg it gives me the following:
./ccg_client: error while loading shared libraries: libSDL-1.2.so.0: cannot open shared object file: No such file or directory
From the error message, it seems clear that the libSDL libraries are either not installed or they cannot be accessed/are miss-located. After checking my packages with dpkg --get-selections | grep libsdl I found out that all the libSDL packages are installed... so just to make sure, I used sudo apt-get purge on all of the libSDL packages and made a clean install on all of the libSDL packages, however, the result is still the same.
Furthermore, when I use apt-file search libSDL-1.2.so.0, to locate the so-called "missing libraries", I get this as a result:
libsdl1.2debian: /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
libsdl1.2debian: /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0.11.3
So, as I figure it, they are there... but they are not shared?
Is this a 32 bits or a 64 bits binary ? ( you can check with file ./Mtg ).
If this is a 32 bits binary, then you need the 32 bits version of libSDL, as you seems to be running x86_64.
Misc
  • 1,092
I needed all those libraries:
sudo apt-get install libsdl1.2debian:i386
sudo apt-get install libsdl-net1.2:i386
sudo apt-get install libsdl-image1.2:i386
sudo apt-get install libjpeg62:i386
sudo apt-get install libsdl-ttf2.0-0:i386
sudo apt-get install libsdl-mixer1.2:i386
