I am on Ubuntu MATE 22.04. After a sudo apt update and sudo apt list --upgradable I get the following output:
apt-utils/jammy-updates 2.4.8 amd64 [upgradable from: 2.4.7]
apt/jammy-updates 2.4.8 amd64 [upgradable from: 2.4.7]
libapt-pkg6.0/jammy-updates 2.4.8 amd64 [upgradable from: 2.4.7]
When I try to upgrade with sudo apt upgrade, all 3 packages are kept back.
If I do sudo nala upgrade instead (nala is just another frontend for apt that I prefer because it is more informative), it explains why some of the packages are kept back:
The following packages were kept back:
apt
└── apt conflicts with apt-transport-https
libapt-pkg6.0
└── libapt-pkg6.0 (!= 2.4.8) will break libapt-pkg
Nala was unable to determine why these were held:
apt-utils
I am confused about the reason that apt is being kept back. It says that apt conflicts with apt-transport-https, but as far as I can tell, apt-transport-https is not installed on my system.
Output of dpkg -l apt-transport*:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un apt-transport-https <none> <none> (no description available)
Output of apt-cache policy libapt-pkg6.0:
libapt-pkg6.0:
Installed: 2.4.7
Candidate: 2.4.8
Version table:
2.4.8 500 (phased 40%)
500 http://mirror.il-jr.kamatera.com/ubuntu jammy-updates/main amd64 Packages
*** 2.4.7 100
100 /var/lib/dpkg/status
2.4.5 500
500 http://mirror.il-jr.kamatera.com/ubuntu jammy/main amd64 Packages
Output of dpkg -l | grep libapt-pkg:
ii libapt-pkg-perl 0.1.40build2 amd64 Perl interface to libapt-pkg
ii libapt-pkg6.0:amd64 2.4.7 amd64 package management runtime library
ii python-apt-common 2.3.0ubuntu2.1 all Python interface to libapt-pkg (locales)
ii python3-apt 2.3.0ubuntu2.1 amd64 Python 3 interface to libapt-pkg
I believe that this issue is not related to phased updates for two reasons:
- From my experience, if packages are held back because of phased updates then nala doesn't specify a reason why they are held back.
- I added the 99-Phased-Updates file to /etc/apt/apt.conf.d to disable phased updates and the issue persists.
Can someone explain this behavior and how to resolve this?
