I'm trying to install Ansible using sudo apt-get install ansible, but I'm getting the following output:
Reading package lists... Done
Building dependency tree... Done
ansible-core : Depends: python3-jinja2 but it is not installable
Depends: python3-packaging but it is not installable
Depends: python3-resolvelib but it is not installable
Recommends: sshpass but it is not installable
How can I install Ansible?
