I am trying to install the SDL2 development headers to compile a program that imports SDL2. Here is the output when I run the command $sudo apt-get install libsdl2-dev:
Reading package lists... Done
Building dependency tree
libsdl2-dev : Depends: libsdl2-2.0-0 (= 2.0.10+dfsg1-3) but 2.0.12+dfsg1-2 is to be installed
Aptitude and Synaptic both suggest downgrading SDL2 to resolve this. I am not comfortable with accepting this since SDL2 is used by other programs. Changing the version might break something else (for all I know.)
I suspect that this is somehow caused by me carelessly using the package manager in the past (it says "you have held broken packages",) so I'd like to actually understand the issue and the solution rather than blindly accepting whatever aptitude suggests.
Thanks
EDIT: My OS is Ubuntu 20.04.5 LTS
