Esperanto uses the letter Ŭ. Compose, Shift+9, a = ă, but Compose, Shift+9, u = u.
How do I type this with the compose key? If that is not possible, what is the next easiest way to type it?
Depends on the version of X11 (assuming you are not using or wayland) and keyboard layout, but generally Compose, b, u or Compose, u, u should work (IIRC Compose, ( was used for breve some (long) time ago).
See also /usr/share/X11/locale/*/Compose.
Ŭ or ŭ is a letter in the Esperanto alphabet, based on u with breve.
Press the Ctrl+Shift+u keyboard combination which will print a u character on the screen. Then after the u type one of the 4-digit hexadecimal codes in the second column and press Enter to render the u+4-digit hexadecimal number that appears on the screen as the appropriate u with breve character.
Character Hex HTML Entity
Ŭ 016c Ŭ
ŭ 016d ŭ
karel
  • 122,292
  • 133
  • 301
  • 332
