I'm trying to connect to an MS SQL Server 2016 from my ubuntu server 22.04.
I've installed the odbc driver following the official MS documentation: https://learn.microsoft.com/en-us/sql/connect/odbc/linux-mac/installing-the-microsoft-odbc-driver-for-sql-server?view=sql-server-ver16
The installation works fine and I can connect to newer MS SQL servers, the problem is to connect to 2016 SQL Server, looks like an issue with OpenSSL version. Ubuntu 22.04 uses by default the openssl 3.x.x.
I've enabled some debug options by adding to /etc/odbcinst.ini
[ODBC]
Trace = Yes
TraceFile = /dev/stdout
And the output doesn't help much. I've found some solutions but are always related to old ubuntu.
Here is the output:
[ODBC][62430][1664301799.879691][__handles.c][460]
        Exit:[SQL_SUCCESS]
            Environment = 0x55b6b35d3870
[ODBC][62430][1664301799.879839][SQLAllocHandle.c][377]
        Entry:
            Handle Type = 2
            Input Handle = 0x55b6b35d3870
        UNICODE Using encoding ASCII 'UTF-8' and UNICODE 'UCS-2LE'
[ODBC][62430][1664301799.880405][SQLAllocHandle.c][513] Exit:[SQL_SUCCESS] Output Handle = 0x55b6b35d4590 [ODBC][62430][1664301799.880465][SQLDriverConnect.c][748] Entry: Connection = 0x55b6b35d4590 Window Hdl = (nil) Str In = [Driver={ODBC Driver 18 for SQL Server};Server=tcp:xxxx,1433;Database=xxx;UID=xxx;PWD=**********;][length = 116 (SQL_NTS)] Str Out = 0x7fffe858da30 Str Out Max = 2048 Str Out Ptr = (nil) Completion = 0 [ODBC][62430][1664301799.903128][__handles.c][460] Exit:[SQL_SUCCESS] Environment = 0x55b6b370ad10 [ODBC][62430][1664301799.903245][SQLGetEnvAttr.c][157] Entry: Environment = 0x55b6b370ad10 Attribute = 65002 Value = 0x7fffe8586090 Buffer Len = 128 StrLen = 0x7fffe858602c [ODBC][62430][1664301799.903298][SQLGetEnvAttr.c][273] Exit:[SQL_SUCCESS] [ODBC][62430][1664301799.903319][SQLFreeHandle.c][220] Entry: Handle Type = 1 Input Handle = 0x55b6b370ad10 DIAG [08001] [Microsoft][ODBC Driver 18 for SQL Server]TCP Provider: Error code 0x2746
    DIAG [08001] [Microsoft][ODBC Driver 18 for SQL Server]Client unable to establish connection
[ODBC][62430][1664301799.903893][SQLDriverConnect.c][1637] Exit:[SQL_ERROR] [ODBC][62430][1664301799.903976][SQLError.c][424] Entry: Connection = 0x55b6b35d4590 SQLState = 0x7fffe858f046 Native = 0x7fffe858f040 Message Text = 0x7fffe858f050 Buffer Length = 500 Text Len Ptr = 0x7fffe858f03e [08001][Microsoft][ODBC Driver 18 for SQL Server]TCP Provider: Error code 0x2746 [08001][Microsoft][ODBC Driver 18 for SQL Server]Client unable to establish connection
Also, I've installed the OpenSSL 1.0.1k manually compiling the code, but looking the strace from the isql or sqlcmd it stills using the openssl 3 has you can see here:
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libcrypto.so.3", O_RDONLY|O_CLOEXEC) = 4
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libssl.so.3", O_RDONLY|O_CLOEXEC) = 4
Do you know how to change the libssl from the odbc drive?
BigLeo
  • 121
