I'm trying to upgrade my WSL2 distro from Impish to Jammy Jellyfish and running into problems with what I assume is systemd. I just installed the new wsl version from the Windows store to enable systemd support and not sure if this is related. Not sure where to go from here.
running sudo do-release-upgrade results in:
Checking for a new Ubuntu release
Your Ubuntu release is not supported anymore.
For upgrade information, please visit:
http://www.ubuntu.com/releaseendoflife
Running 'sudo apt upgrade' results in:
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
 libnss-systemd : Depends: systemd (= 248.3-1ubuntu8.6) but 248.3-1ubuntu8.2 is installed
 libpam-systemd : Depends: systemd (= 248.3-1ubuntu8.6) but 248.3-1ubuntu8.2 is installed
 systemd : Depends: libsystemd0 (= 248.3-1ubuntu8.2) but 248.3-1ubuntu8.6 is installed
 systemd-sysv : Depends: systemd (= 248.3-1ubuntu8.6) but 248.3-1ubuntu8.2 is installed
 systemd-timesyncd : Depends: systemd (= 248.3-1ubuntu8.6) but 248.3-1ubuntu8.2 is installed
 udev : Breaks: systemd (< 248.3-1ubuntu8.6) but 248.3-1ubuntu8.2 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Running sudo apt --fix-broken install results in:
Correcting dependencies... Done
The following additional packages will be installed:
  systemd
Suggested packages:
  systemd-container
The following packages will be upgraded:
  systemd
1 upgraded, 0 newly installed, 0 to remove and 126 not upgraded.
4 not fully installed or removed.
Need to get 0 B/4405 kB of archives.
After this operation, 4096 B disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 45441 files and directories currently installed.)
Preparing to unpack .../systemd_248.3-1ubuntu8.6_amd64.deb ...
Unpacking systemd (248.3-1ubuntu8.6) over (248.3-1ubuntu8.2) ...
dpkg: error processing archive /var/cache/apt/archives/systemd_248.3-1ubuntu8.6_amd64.deb (--unpack):
 unable to make backup link of './usr/lib/tmpfiles.d/tmp.conf' before installing new version: Invalid cross-device link
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Adam
  • 31
Figured it out between a few different but semi-related issues. Simply, I think it was just needing to reinstall systemd. The following worked for me:
# Reverting to old sources:
sudo sed -i -re 's/([a-z]{2}\.)?archive.ubuntu.com|security.ubuntu.com/old-releases.ubuntu.com/g' /etc/apt/sources.list
Reinstall systemd:
sudo apt install --reinstall systemd
#Update distro: sudo apt update && sudo apt upgrade
Upgrade to new version:
NotTheDr01ds
  • 22,082
Adam
  • 31
