How do you install AMD GPU drivers for Ubuntu 22.04 LTS (Desktop)? It only installs the archive and not the drivers.
Well I suppose you have installed the deb from amd.com, and looked at https://amdgpu-install.readthedocs.io/en/latest/
However, these instructions do not currently work, it seems. A lot of people around the interwebs have the same problem.
A couple of solutions have been presented, ie Unmet dependencies ubuntu 22.04 & amdgpu HIP support
But I myself haven't gotten any proposed solution to work. It seems we have to wait until amd at a random moment decides to actually fix this....
- 106
- 1
- 4
I ended up having to downgrade to Ubuntu 20.04. AMD drivers work fine with that, could not get them to work in 22.04 no matter what I tried.
- 51
For Ubuntu 22.04 LTS Register kernel-mode driver.
Registering repositories
# Make the directory if it doesn't exist yet.
# This location is recommended by the distribution maintainers.
sudo mkdir --parents --mode=0755 /etc/apt/keyrings
Download the key, convert the signing-key to a full
keyring required by apt and store in the keyring directory
wget https://repo.radeon.com/rocm/rocm.gpg.key -O - |
gpg --dearmor | sudo tee /etc/apt/keyrings/rocm.gpg > /dev/null
Add the AMDGPU repository for the driver.
echo "deb [arch=amd64 signed-by=/etc/apt/keyrings/rocm.gpg] https://repo.radeon.com/amdgpu/6.0.2/ubuntu jammy main" \
| sudo tee /etc/apt/sources.list.d/amdgpu.list
sudo apt update
Install kernel driver
sudo apt install amdgpu-dkms
sudo reboot
Then run sudo dpkg-reconfigure amdgpu-dkms
- 156
These are the official guideline to install proprietary AMD graphic drivers:
- go to https://www.amd.com/en/support/download/linux-drivers.html and download the correct driver
- launch: (package name may change)
sudo dpkg -i ./amdgpu-install_....deb
sudo amdgpu-install -y --usecase=graphics,rocm
sudo usermod -a -G render,video $LOGNAME
- reboot
It takes a lot of time, because it compiles all possible amdgpu modules, but it works.
It works for me with an amd radeon rx580 on Ubuntu 22.04.1 LTS. I use the 22.20.50204-1 version of the amd driver with linux-image-5.15.0-46-generic. I noticed this when I tried to fix the system when gui crashed on booting after installing the driver on a newer kernel version.
I chrooted from usb and removed all installed kernel versions as I knew there was trouble with newer kernels with another, a bit older, amd driver. Then I forgot to install the kernel version I had planned to install before i started the amdgpu-install in the chrooted system.
I used it with workstation profile, legacy opengl and vulkan pro and the installer installed the 5.15.0-46 kernel as dependency. All worked fine, modules were compiled and system is running with the new driver. I blocked the installation of newer kernel versions for the moment, but I will test newer ones from time to time ;-)
- 2,242
The solution that worked for me -
I installed the gdebi package
sudo apt install gdebi
Then I went to and GPU drivers for linux
I downloaded the driver for Ubuntu 22.04. It is named amdgpu-install
I installed it using -
sudo gdebi amdgpu-install
Then,
- 315
- 1
- 2
- 12
