This is what I get when I execute following command:
sudo apt-get dist-upgrade
Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following package was automatically installed and is no longer required: libfwupdplugin1 Use 'sudo apt autoremove' to remove it. The following NEW packages will be installed: libnvidia-egl-wayland1 The following packages will be upgraded: libnvidia-cfg1-470 libnvidia-common-470 libnvidia-compute-470 libnvidia-decode-470 libnvidia-encode-470 libnvidia-extra-470 libnvidia-fbc1-470 libnvidia-gl-470 libnvidia-ifr1-470 nvidia-compute-utils-470 nvidia-dkms-470 nvidia-driver-470 nvidia-kernel-common-470 nvidia-kernel-source-470 nvidia-utils-470 xserver-xorg-video-nvidia-470 16 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. 16 standard security updates Need to get 234 MB of archives. After this operation, 2 392 kB of additional disk space will be used. Do you want to continue? [Y/n] Y WARNING: The following packages cannot be authenticated! libnvidia-egl-wayland1 Install these packages without verification? [y/N] y Err:1 http://archive.ubuntu.com/ubuntu impish/universe amd64 libnvidia-egl-wayland1 amd64 1:1.1.7-2build1 404 Not Found [IP: 91.189.91.38 80] ... E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
