W: Skipping acquire of configured file 'main'./binary-i386/Packages' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./binary-amd64/Packages' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./i18n/Translation-ka_GE' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./i18n/Translation-en' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./i18n/Translation-en_US' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./i18n/Translation-ka' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./dep11/Components-amd64.yml' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./dep11/icons-48x48.tar' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./dep11/icons-64x64.tar' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./dep11/icons-64x64@2.tar' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?) W: Skipping acquire of configured file 'main'./cnf/Commands-amd64' as repository 'http://archive.ubuntu.com/ubuntu focal InRelease' doesn't have the component 'main'.' (component misspelt in sources.list?)**strong text**
Asked
Active
Viewed 867 times
-1
In terminal execute the following command
sudo grep -i postgresql /etc/apt/sources.list
Now edit the /etc/apt/sources.list using;
`sudo gedit /etc/apt/sources.list`
and change the line that begins with
deb https:// to deb [arch=amd64] https:// and save the file.
Arjun K Shibu
- 1,278
Without more contextual information this may not be the answer you are looking for, but I had a similar issue when updating my own box:
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://pkg.cloudflare.com/cloudflared focal InRelease' doesn't support architecture 'i386'
I cleared this message by navigating to /etc/apt/sources.list.d/ and deleting the contents of that directory with rm.
Note my box is running Ubuntu Server 20.04, and I no longer had need of that repository. Not sure what your circumstances are.
WifiJedi
- 15
