I don't know if this is a local bash setting on my part, but when I cut a line within a terminal (or gnu screen) using Ctrl+k, the result isn't copied to GPaste. Instead, the copied text can only be pasted within that terminal. Is there a way to modify my .bashrc file to get the desired behavior of adding the cut text to the clipboard?
I found a solution for a Mac running zsh here, but I don't know how to implement it in bash.
