I am trying to download mlt module glaxnimate for Kdenlive when I run Kdenlive it show I am trying download it from github but unable to get execute after I run
  git clone https://github.com/mltframework/mlt/releases/download/v7.8.0/mlt-
7.8.0.tar.gz
Cloning into 'mlt-7.8.0.tar.gz'...
remote: Not Found
fatal: repository 'https://github.com/mltframework/mlt/releases/download/v7.8.0/mlt-
7.8.0.tar.gz/' not found
when I try to add through clone my Ubuntu version
Distributor ID:   Ubuntu
Description:  Ubuntu 22.04.1 LTS
Release:   22.04
Codename:  jammy
hardware
Terminal: gnome-terminal
Intel CPU: Intel i5-8250U (8) @ 3.400GHz
GPU: Intel UHD Graphics 620
GPU: AMD ATI Radeon R7 M260/M265 / M340/M360 / M440/M445 /
530/535 / 620/625 Mobile
Kdenlive is 22.08.1
I have resolve it by Download AppImage file of kdenlive
First uninstall kdenlive after that run
sudo apt install libfuse2
it is required to run AppImage file then Download The Kdenlive AppImage after that right click on it In the next screen, go to the Permissions tab and check the box that says “Allow executing file as program” double click on it it will run
In addition to Sarthak's answer, if you try installing it and it says it's installed, you'll need to reinstall it with the following command.
sudo apt reinstall libfuse2
Not sure what triggers needed to be reprocessed, but KDEnlive opens just fine after that.
