Update
  • By trying different things and installing more AMD packages I have managed to get to the "Uh oh...something went wrong" screen before the user list is presented.
  • But when I used my USB stick with Try Ubuntu 22.04 I found that I could see both monitors and drag screens between them. So somehow the USB ISO is smarter than the installed one (I did install from that exact USB). I just edited the question in case this detail helps (?).
  • By using the advance recovery boot mode I was just able to get past the "Uh oh" screen by removing recently added packages, but now I'm back to where only one monitor works.
Hardware/Software:
        sudo lshw -c video
        [sudo] password for user:
          *-display UNCLAIMED
               description: VGA compatible controller
               product: Navi 23 [Radeon RX 6600/6600 XT/6600M]
               vendor: Advanced Micro Devices, Inc. [AMD/ATI]
               physical id: 0
               bus info: pci@0000:12:00.0
               version: c7
               width: 64 bits
               clock: 33MHz
               capabilities: pm pciexpress msi vga_controller bus_master cap_list
               configuration: latency=0
               resources: iomemory:7c0-7bf iomemory:7e0-7df memory:7c00000000-7dffffffff memory:7e00000000-7e0fffffff ioport:f000(size=256) memory:fcc00000-fccfffff memory:fcd00000-fcd1ffff
          *-graphics
               product: EFI VGA
               physical id: 1
               logical name: /dev/fb0
               capabilities: fb
               configuration: depth=32 resolution=1920,1080
    user@xxxxxx:/mnt/6TBNumber1A/archive4$ sudo xrandr --verbose --listmonitors
    xrandr: Failed to get size of gamma for output default
    Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
    default connected primary 1920x1080+0+0 (0x523) normal (normal) 0mm x 0mm
        Identifier: 0x522
        Timestamp:  152469548
        Subpixel:   unknown
        Clones:
        CRTC:       0
        CRTCs:      0
        Transform:  1.000000 0.000000 0.000000
                    0.000000 1.000000 0.000000
                    0.000000 0.000000 1.000000
                   filter:
        _MUTTER_PRESENTATION_OUTPUT: 0
        non-desktop: 0
            supported: 0, 1
      1920x1080 (0x523) 159.667MHz *current
            h: width  1920 start    0 end    0 total 1920 skew    0 clock  83.16KHz
            v: height 1080 start    0 end    0 total 1080           clock  77.00Hz
    uname -a
    Linux xxxxx 5.15.0-46-generic #49-Ubuntu SMP Thu Aug 4 18:03:25 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Machine: MSI Aegis ZS 5DQ-274US AMD Ryzen™ 7 5700G 8C/16T 3.8-4.6 Ghz 16MB Cache Chipset B550 MSI MicroATX Motherboard AMD Radeon™ RX 6600 8GB GDDR6 128-bit Graphics Card Outputs: 1 HDMI and 3 DP My monitors support HDMI only, I use a dongle for DP => HDMI
My Efforts
I am a long time Ubuntu user but never had a problem with monitor detection before. I do believe I am out of my depth on this. I have tried installing the .deb file from here based on this previous question along with the 2 usermod commands cited.
I have tried using Ctrl-Alt-F1 and Ctrl-Alt-F7, plus xrandr --auto and systemctl restart gdm from this previous question.
user@xxxxxx:/mnt/6TBNumber1A/archive4$ sudo xrandr --auto
The 6600 came with the retail PC I bought, I am willing to replace it with a more Ubuntu friendly one that can support at least 2 HDMI monitors. Please feel free to suggest a cheaper/simpler graphics card I could use and maybe sell the 6600. I am not a gamer.
This is my first askubuntu question, I tried to do as good a job as I could in providing detail.
legacyp222
Answering My Own Question
OK folks, I finally got the personal time to re-install 22.04 LTS on my server (and all the attendant redoing of samba, fstab, apache2, mysql, etc.)
This time though, I purposely did NOT install the proprietary Radeon graphics drivers, and that resulted in me having both monitors available not only during the "Try Ubuntu" but also after I had installed.
Also, this time I tried to make changes in groups, restarting after each set of changes. I started with fstab for the many UUID to /mnt mappings on this server.
It turns out I had a mistake in fstab which (apparently) resulted in network errors (unable to resolve DNS). Of course I only realized the connection once I eliminated any problem with my network setup, and stumbled on a comment via Googling that the network won't come up if the local file system has a problem.
I fixed fstab, rebooted and I had both monitors working, and there was much rejoicing! Also, I have been through additional reboots since then and I still have 2 working monitors.
Sorry, I did not intend to give insufficient information for folks to help me resolve the problem. I had not noticed the network errors, nor did I know my fstab was bad.
legacyp222
