I have 3 1TB HDDs, that I'm trying to format and mount in linux. I can`t create partitions delete or format that drives, but they are completely clean, i already deleted windows (I disabled windows fast boot). In windows disks work perfectly.
In GParted (GUI) I see:
partition - unallocated file system - unallocated warning - unrecognised disk label
When im trying to mount drive, i get this :
mount: wrong fs type, bad option, bad superblock on /dev/sda, missing codepage or helper program, or other error
Here are some screenshots from fsdisk and lsblk (Talking about drives sda, sdb, sdd) : https://i.sstatic.net/7SE8d.jpg
When I try to create partitions using the fdisk /dev/sda command, it says that the partitions have been created, but in fact they are not created
UPD : I use Kubuntu 22.04.1 LTS Here are some screenshots from GParted : https://i.sstatic.net/NGd8D.jpg When I try to create a partition table, it just loads and nothing happens, you can see it in one of the screenshots
UPD 2.0 : After using mkusb i still can`t use partition tools, but this time i tried to format drive also in KDE partition manager, and i revieved following errors : https://i.sstatic.net/zpAH2.jpg
Data from the drives does not matter, just help me to make able to use them.
