I am an absolute newbie so I don't really understand command prompt.
I have downloaded gimp-gap (Is that the best one to use?).
I want to make an animated gif from frames of a movie.
I have a series of frames in .png that I took from a dvd using vlc video capture.
but then what do I do?
I have opened gimp, clicked file-open as layers then selected the files.
They appear to load in but then just one huge image comes up in gimp.
I have no idea what to do...
Not even sure if that was the correct first step!
Aaargh! Am so confused. I have been searching web for hours but can only seem to find instruction for windows and photoshop or something.
Am nearly in tears please help if you can. Thank you.
Carla
  • 113
You can navigate to this question
First command above create sequence of images. Second command puts images into on gif-file:
Also, you can use optimization level flag --optimize=03. It can be helpful to reduce file size:
Additionally, you can manipulate with number of colors --colors num of current palette and --color-method method to determine most appropriate palette.
As for me most appropriate method is median-cut
median-cut is the median cut algorithm described by Heckbert
Also, I try to manipulate with described flags and found most useful options to achieve better quality of generated gif-image:
gifsicle --delay=3 --optimize=03 --color-method median-cut --loop *.gif > anim.gif
Be accurate with --delay=NUM to correspond animation speed . This param depends on FPS of original video.
You don't need GIMP to merge several files into animation, you can do that with imagemagick. Have a go at http://www.imagemagick.org/Usage/anim_basics/
If your images have the same sizes just install imagemagick, open a terminal, got to the directory where the images are, and convert them:
sudo apt-get install imagemagick
cd ~/Images
If you really need GIMP, then please read http://www.gimp.org/tutorials/Simple_Animations/
