I'm on Ubuntu 22.04.01 LTS.
There are similar questions, but the poster was already much further along before posting and I don't know how to get to their initial step.
What's happening?
When I turn on my computer it boots to emergency mode. I was able to print the journal and have included photos further down.
There are options to go to recovery mode. When I'm in recovery mode I can't move down the menu, but am able to write into a command line.
How did this happen?
An external HD suddenly wouldn't mount. It's NTFS and I concluded there was some read/write issue. Therefore I found some code online. After entering this code I rebooted. This is when the issues started. My OS is on an internal drive and I'm fairly sure its file system is fuse.
This is the code I entered. The code executed.
sudo apt-get purge ntfsprogs
sudo apt-get purge ntfs-3g
sudo apt-get install ntfs-3g
Examples of errors
I've photographed some of the journal. If there's a better way please let me know.
- These are images of journal output that have coloured lines: https://postimg.cc/gallery/0mhcKJP
- And here are images of white-coloured lines of code: https://postimg.cc/gallery/z84GL6n
I don't understand how an NTFS.
EDIT 1:
It wouldn't let me boot into recovery mode unless the external HD was connected. Weird. As said previously my OS is on an internal.
EDIT 2:
Tried
fsck /dev/nvme0n1p2
Output was
fsck from util-linux 2.37.2
e2fsck 1.46.5 (30-Dec-2021)
/dev/nvme0n1p2 is mounted.
e2fsck: cannot continue, aborting
EDIT 3:
Tried
fsck -nf /dev/nvme0n1p2
The output is here: https://postimg.cc/Th9Hx2vM
I then tried to unmount the drive but it said 'target is busy.'
