So my friend have a really old laptop it got so slow it is unworkable on, I suggested him to install Ubuntu and remove Windows 10 which was installed. I was a supervisor of the process although it is my first time "installing" Linux, but I have a high technical knowledge. the problem start when my friend have 1 HDD drive with 3 partitions and all are MBR and NTFS format. he have data on D:\ and E:\ so we formatted just the C:\ (WinOS) and after problems and struggles we installed it with Grub and it boots very well. Now we have the problem of the D:\ and E:\ drives loading on read-only because we haven't disabled fast startup on Windows before uninstalling it...
Edit: not long after we tried booting into windows with a CD and then tried to turn off hibernation options using the installation cmd, it didn't work as it can't be configured from within the installer, my friend booted into ubuntu did some suggested updates (by the Ubuntu OS) and restarted and for some unknown reasons, they allowed for writing on them along the reading allowed before.
ntfs is a proprietary file system. Therefore, the only thorough tools to check and repair an ntfs file system are the tools of MS Windows.
As a general rule, only keep ntfs partitions around if you can connect them now and then to a windows machine.
In this case, the ntfs partitions are on an internal drive in a computer without windows. Therefore, the only sound advice here is to reformat these partitions to a linux file system such as ext4, the default file system of Ubuntu.
Ubuntu still mounts the partitions read-only. This is because writing could further damage the file system. It means you still can read the data. Update your backup of that data before converting the file system. Reformatting the partitions will erase all data.
vanadium
  • 97,564
