20
I have a strange problem that my mouse keeps selecting everything I point to. For example, if I open Rhythmbox, then at the top of the screen there is a text which says which song is playing. If I move my mouse over this text, then it will select this text; but I am not clicking.
This behaviour does not happen in all programs. For example in Firefox I have no problem at all. Maybe it is Gtk related? Nautilus also behaves strangely; I cannot open files by clicking on them, I have to select and make a box around the file and then press enter to open it. If I click, then nothing happens. Similar problems also happen with other Gtk software.
I think the problem might be related to touchscreen issues (I have a touchscreen). I run Gnome 3 on Ubuntu 12.04. I have a HP touchsmart 610 desktop computer. Any help is greatly appreciated.
UPDATE: I just did a fresh reinstall, and I am 90% certain that it is related to the touchscreen drivers. Here is what happens when I reinstall. At first boot, so exactly after install, everything works fine, except the touchscreen: The touchscreen does not respond. I update ubuntu, because I installed from an old CD (CD with ub. 12.04). Then on next reboot I have touchscreen working , but the working touchscreen comes together with the mouse selecting everything on its own.
SECOND QUESTION: Would anybody know how I could figure out what those touchscreen drivers are (so that I can disable them) ?
mnr
  • 1,017
5 Answers5
46
Touch your screen to make it stop.
I have the same problem on a touchscreen machine. It just happened now, and I decided to see if someone offered a solution. @mnr's mention that it might be touchscreen-related made me try: Touching the screen made the mouse stop auto-highlighting.
Rasmus
  • 8,655
Got to System Settings -> Universal Access -> Pointing and Clicking:
Make sure you have not activated Hover Click
Nicolas Raoul
  • 11,921
Takkat
  • 144,580
There is a bug in X and it's already reported. Sadly it took a while for them to realize that it's made by X.
Eric Carvalho
  • 55,453
Tommy
  • 84
In my case, it was my mouse cord on top of the touchpad the one created the mayhem. It took me a shameful time to figure this out...
Nico
  • 111
I experienced the same problem on Ubuntu 20.04 with a touchscreen. The solution proposed by Rasmus (touch the screen) solved the problem. If (like me) you don't use the touch screen without a pen, you can disable the "finger" part of it using the following command:
xinput disable "$( xinput list | grep -i Finger | sed '/Finger/s/^.*id=\([0-9]*\).*$/\1/' )"
(you can reenable it using the xinput enable command with the same argument)
