I want to install new package on ubuntu18.04 and I think I installed incorrectly some Ubuntu 20 packages and when I want to install some packages like:
sudo apt-get install libgtest-dev
I got this message:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libgtest-dev : Depends: googletest (= 1.10.0-2~18.04.sav0) but it is not going to be installed
libncurses5 : Depends: libtinfo5 (= 6.1-1ubuntu1.18.04) but 6.2-0ubuntu2 is to be installed
libncurses5-dev : Depends: libtinfo5 (= 6.1-1ubuntu1.18.04) but 6.2-0ubuntu2 is to be installed
libncursesw5 : Depends: libtinfo5 (= 6.1-1ubuntu1.18.04) but 6.2-0ubuntu2 is to be installed
libncursesw5-dev : Depends: libtinfo5 (= 6.1-1ubuntu1.18.04) but 6.2-0ubuntu2 is to be installed
libtinfo-dev : Depends: libtinfo5 (= 6.1-1ubuntu1.18.04) but 6.2-0ubuntu2 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
But by running this command:sudo apt --fix-broken install I got this message:
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
And as obvious in this message a dozen of packages will be removed. how could I do that without removing these packages.
Full message is :
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
accountsservice acl amd64-microcode apg apport-symptoms appstream apt-config-icons aptdaemon-data aptitude-common avahi-utils blt bluez-obexd busybox-initramfs
ca-certificates-java cheese-common cmake-data colord-data command-not-found-data cracklib-runtime cuda-command-line-tools-11-4 cuda-compiler-11-4
cuda-cuobjdump-11-4 cuda-cupti-11-4 cuda-cupti-dev-11-4 cuda-cuxxfilt-11-4 cuda-documentation-11-4 cuda-gdb-11-4 cuda-libraries-11-4 cuda-libraries-dev-11-4
cuda-memcheck-11-4 cuda-nsight-11-4 cuda-nsight-compute-11-4 cuda-nsight-systems-11-4 cuda-nvdisasm-11-4 cuda-nvml-dev-11-4 cuda-nvprof-11-4 cuda-nvprune-11-4
cuda-nvrtc-11-4 cuda-nvrtc-dev-11-4 cuda-nvtx-11-4 cuda-nvvp-11-4 cuda-samples-11-4 cuda-sanitizer-11-4 cuda-toolkit-11-4 cuda-tools-11-4 cuda-visual-tools-11-4
cups-pk-helper cups-server-common dc debhelper dh-autoreconf dh-strip-nondeterminism diffstat distro-info distro-info-data dns-root-data dnsmasq-base
docutils-common docutils-doc fonts-dejavu-extra fonts-elusive-icons fonts-font-awesome fonts-lato fonts-mathjax gcr gdal-data gdbserver gir1.2-accountsservice-1.0
gir1.2-appindicator3-0.1 gir1.2-atspi-2.0 gir1.2-dbusmenu-glib-0.4 gir1.2-dee-1.0 gir1.2-gck-1 gir1.2-gcr-3 gir1.2-gdesktopenums-3.0 gir1.2-gdm-1.0
gir1.2-geoclue-2.0 gir1.2-gnomebluetooth-1.0 gir1.2-gnomedesktop-3.0 gir1.2-goa-1.0 gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0 gir1.2-gtk-2.0
gir1.2-gtksource-3.0 gir1.2-gudev-1.0 gir1.2-gweather-3.0 gir1.2-harfbuzz-0.0 gir1.2-javascriptcoregtk-4.0 gir1.2-mutter-2 gir1.2-nm-1.0 gir1.2-nma-1.0
gir1.2-notify-0.7 gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0 gir1.2-rsvg-2.0 gir1.2-secret-1 gir1.2-snapd-1 gir1.2-totemplparser-1.0 gir1.2-udisks-2.0
gir1.2-unity-5.0 gir1.2-upowerglib-1.0 gir1.2-vte-2.91 gir1.2-webkit2-4.0 gir1.2-wnck-3.0 gjs gkbd-capplet gnome-control-center-faces gnome-keyring-pkcs11
gnome-session-common gnome-settings-daemon-schemas gnome-shell-common gnome-software-common gnome-terminal-data gnome-themes-extra gnome-themes-extra-data
gnome-todo-common gnome-user-guide gnupg-l10n gnupg-utils grilo-plugins-0.3-base gstreamer1.0-clutter-3.0 gstreamer1.0-x gtk2-engines-pixbuf gvfs-libs icu-devtools
ifupdown initramfs-tools-bin intel-microcode intltool-debian ippusbxd iputils-arping iucode-tool javascript-common klibc-utils liba52-0.7.4 libaccountsservice0
libalgorithm-c3-perl libappconfig-perl libappstream-glib8 libappstream4 libapt-pkg-perl libarchive-cpio-perl libarchive-zip-perl libaribb24-0 libarmadillo8
libarpack2 libart-2.0-2 libatasmart4 libatk-wrapper-java libatk-wrapper-java-jni libatopology2 libavc1394-0 libavresample-dev libb-hooks-endofscope-perl
libb-hooks-op-check-perl libb64-0d libbabeltrace1 libbasicusageenvironment1 libblockdev-fs2 libblockdev-loop2 libblockdev-part-err2 libblockdev-swap2
libblockdev-utils2 libblockdev2 libbluetooth3 libboost-atomic-dev libboost-container-dev libboost-context-dev libboost-coroutine-dev libboost-date-time-dev
libboost-exception-dev libboost-fiber-dev libboost-filesystem-dev libboost-graph-dev libboost-graph-parallel-dev libboost-locale-dev libboost-log-dev
libboost-math-dev libboost-mpi-dev libboost-numpy-dev libboost-program-options-dev libboost-random-dev libboost-serialization-dev libboost-signals-dev
libboost-stacktrace-dev libboost-system-dev libboost-test-dev libboost-timer-dev libboost-tools-dev libboost-type-erasure-dev libboost-wave-dev libbrlapi0.6
libc6-dbg libcairo-script-interpreter2 libcddb2 libcdio-cdda2 libcdio-paranoia2 libcdio17 libcharls1 libclass-accessor-perl libclass-c3-perl libclass-c3-xs-perl
libclass-data-inheritable-perl libclass-inspector-perl libclass-load-perl libclass-method-modifiers-perl libclass-mix-perl libclass-singleton-perl
libclass-std-fast-perl libclass-std-perl libclone-perl libclutter-gst-3.0-0 libcolord-gtk1 libcolorhug2 libconvert-binhex-perl libcpanel-json-xs-perl libcrack2
libcrypt-eksblowfish-perl libcrypt-rijndael-perl libcryptsetup12 libcufft-11-4 libcufft-dev-11-4 libcupscgi1 libcupsmime1 libcurand-11-4 libcurand-dev-11-4
libcusolver-11-4 libcusolver-dev-11-4 libcusparse-11-4 libcusparse-dev-11-4 libdap25 libdapclient6v5 libdata-entropy-perl libdata-float-perl libdata-optlist-perl
libdate-manip-perl libdatetime-locale-perl libdatetime-perl libdatetime-timezone-perl libdbd-mysql-perl libdbi-perl libdbus-1-dev libdc1394-22-dev
libdevel-callchecker-perl libdevel-caller-perl libdevel-lexalias-perl libdevel-stacktrace-perl libdevice-serialport-perl libdmapsharing-3.0-2 libdrm-dev libdv4
libdvbpsi10 libdw1 libdynaloader-functions-perl libebackend-1.2-10 libebml4v5 libebook-1.2-19 libebook-contacts-1.2-2 libedata-book-1.2-25 libedata-cal-1.2-28
libegl1-mesa-dev libemail-date-format-perl libemail-valid-perl libepoxy-dev libepsilon1 libeval-closure-perl libexception-class-perl libexempi3 libexif-dev
libexif-doc libexporter-tiny-perl libfftw3-single3 libfile-sharedir-perl libfile-slurp-perl libfile-stripnondeterminism-perl libfreexl1 libfyba0 libgail-3-0
libgdal20 libgdcm2-dev libgdcm2.8 libgdm1 libgeos-3.6.2 libgeos-c1v5 libgeotiff2 libgif7 libgjs0g libgl1-mesa-dev libgl2ps1.4 libgles1 libgles2-mesa-dev
libglu1-mesa libglvnd-core-dev libglvnd-dev libgnome-autoar-0-0 libgnome-bluetooth13 libgnome-todo libgnomekbd-common libgnomekbd8 libgoa-backend-1.0-1 libgom-1.0-0
libgphoto2-dev libgpm2 libgpod-common libgpod4 libgraphite2-dev libgrilo-0.3-0 libgroupsock8 libgspell-1-1 libgspell-1-common libgtop-2.0-11 libgtop2-common
libgutenprint2 libharfbuzz-gobject0 libhdf4-0-alt libhdf5-openmpi-100 libhpmud0 libhttp-lite-perl libicu-le-hb0 libiculx60 libiec61883-0 libieee1284-3
libilmbase-dev libimage-base-bundle-perl libimage-info-perl libimobiledevice6 libio-interface-perl libio-pty-perl libio-sessiondata-perl libio-socket-multicast-perl
libio-string-perl libio-stringy-perl libipc-run-perl libjs-jquery libjs-mathjax libjs-modernizr libjs-sphinxdoc libjs-underscore libjson-maybexs-perl libjwt0
libklibc libkmlbase1 libkmldom1 libkmlengine1 libldb1 liblept5 liblirc-client0 liblist-moreutils-perl liblivemedia62 liblua5.1-0 liblua5.3-0 libluajit-5.1-2
libluajit-5.1-common libmad0 libmail-sendmail-perl libmatroska6v5 libmediaart-2.0-0 libmicrodns0 libmime-lite-perl libmime-tools-perl libmime-types-perl libminizip1
libmodule-implementation-perl libmodule-runtime-perl libmozjs-52-0 libmpdec2 libmpeg2-4 libmro-compat-perl libmtp-common libmtp-runtime libmtp9 libmutter-2-0
libnamespace-autoclean-perl libnamespace-clean-perl libndp0 libnet-dns-perl libnet-domain-tld-perl libnet-ip-perl libnet-sftp-foreign-perl libnetcdf-c++4
libnetcdf13 libnetplan0 libnfs11 libnm0 libnma0 libnpp-11-4 libnpp-dev-11-4 libnss-myhostname libntfs-3g88 libnumber-bytes-human-perl libnvidia-cfg1-470
libnvidia-common-470 libnvidia-decode-470 libnvidia-encode-470 libnvidia-extra-470 libnvidia-fbc1-470 libnvidia-gl-470 libnvidia-ifr1-470 libnvjpeg-11-4
libnvjpeg-dev-11-4 libodbc1 libogdi3.2 libopencv-calib3d-dev libopencv-calib3d3.2 libopencv-core-dev libopencv-core3.2 libopencv-features2d-dev
libopencv-features2d3.2 libopencv-flann-dev libopencv-flann3.2 libopencv-highgui-dev libopencv-highgui3.2 libopencv-imgcodecs-dev libopencv-imgcodecs3.2
libopencv-imgproc-dev libopencv-imgproc3.2 libopencv-ml-dev libopencv-ml3.2 libopencv-objdetect-dev libopencv-objdetect3.2 libopencv-photo-dev libopencv-photo3.2
libopencv-shape-dev libopencv-shape3.2 libopencv-stitching-dev libopencv-stitching3.2 libopencv-superres-dev libopencv-superres3.2 libopencv-ts-dev
libopencv-video-dev libopencv-video3.2 libopencv-videoio-dev libopencv-videoio3.2 libopencv-videostab-dev libopencv-videostab3.2 libopenexr-dev libopengl0
libopenmpt-modplug1 liborc-0.4-dev liborc-0.4-dev-bin libossp-uuid-perl libossp-uuid16 libpackage-stash-perl libpackage-stash-xs-perl libpackagekit-glib2-18
libpadwalker-perl libparams-classify-perl libparams-util-perl libparams-validationcompiler-perl libparse-debianchangelog-perl libparted-fs-resize0 libpcre16-3
libpcre3-dev libpcre32-3 libpcrecpp0v5 libpeas-common libperlio-gzip-perl libphonenumber7 libphp-serialization-perl libpixman-1-dev libplacebo4 libplist3
libplymouth4 libpolkit-agent-1-0 libpolkit-backend-1-0 libpq5 libproj12 libproxy-tools libpulse-mainloop-glib0 libpwquality-common libpwquality1
libpython2.7-minimal libpython3.6-minimal libqhull7 libqt5multimedia5 libqt5multimediawidgets5 libqt5x11extras5 libraw1394-dev libraw1394-tools libreadline5
libreadonly-perl libref-util-perl libref-util-xs-perl libregina3 libresid-builder0c2a librhash0 librole-tiny-perl libsane-common libsane-hpaio libsdl2-2.0-0
libserf-1-1 libsgutils2-2 libshout3 libsidplay2 libsigc++-2.0-0v5 libsnmp-base libsnmp30 libsoap-lite-perl libsoap-wsdl-perl libsocket++1 libspatialite7
libspecio-perl libssh2-1 libstartup-notification0 libstemmer0d libsub-exporter-perl libsub-exporter-progressive-perl libsub-identify-perl libsub-install-perl
libsub-quote-perl libsuperlu5 libsvn1 libsys-cpu-perl libsys-hostname-long-perl libsys-meminfo-perl libsys-mmap-perl libsysmetrics1 libtag1v5 libtag1v5-vanilla
libtalloc2 libtask-weaken-perl libtbb-dev libtbb2 libteamdctl0 libtemplate-perl libterm-readkey-perl libtesseract4 libtevent0 libtext-levenshtein-perl libtiff-dev
libtracker-sparql-2.0-0 libudisks2-0 libupnp6 libupower-glib3 liburi-encode-perl liburiparser1 libusageenvironment3 libusbmuxd4 libuv1 libva-wayland2
libvariable-magic-perl libvlc-bin libvlc5 libvlccore9 libwayland-bin libwayland-dev libwbclient0 libwhoopsie-preferences0 libwhoopsie0 libwnck-3-0 libwnck-3-common
libx11-xcb-dev libxapian30 libxatracker2 libxcb-dri2-0-dev libxcb-dri3-dev libxcb-glx0-dev libxcb-present-dev libxcb-randr0-dev libxcb-render0-dev libxcb-res0
libxcb-shape0-dev libxcb-shm0-dev libxcb-sync-dev libxcb-xfixes0-dev libxcb-xv0 libxcomposite-dev libxcursor-dev libxdamage-dev libxerces-c3.2 libxfixes-dev
libxfont2 libxi-dev libxinerama-dev libxkbcommon-dev libxklavier16 libxml-libxml-perl libxml-namespacesupport-perl libxml-sax-base-perl libxml-sax-expat-perl
libxml-sax-perl libxml-simple-perl libxml2-utils libxmlrpc-lite-perl libxnvctrl0 libxrandr-dev libxres1 libxshmfence-dev libxtst-dev libxvmc1 libxxf86vm-dev
libyaml-0-2 libyaml-libyaml-perl libzeitgeist-2.0-0 lintian linux-generic-hwe-18.04 linux-headers-generic-hwe-18.04 linux-image-generic-hwe-18.04 linux-sound-base
llvm-6.0 llvm-6.0-runtime mesa-common-dev mobile-broadband-provider-info mpi-default-bin mscompress mutter-common nautilus-data ncurses-term nsight-compute-2021.2.2
nsight-systems-2021.3.2 nvidia-compute-utils-470 nvidia-modprobe nvidia-utils-470 odbcinst odbcinst1debian2 opencv-data openssh-sftp-server p11-kit p11-kit-modules
pandoc pandoc-data patchutils php-apcu php-apcu-bc php-gd php-intl php7.2-gd php7.2-intl po-debconf proj-bin proj-data python-apt-common python-babel-localedata
python-minimal python-pip-whl python-qtawesome-common python2.7-minimal python3-minimal python3.6-minimal rhythmbox-data session-migration sgml-base sphinx-common
sphinx-rtd-theme-common spyder-common syslinux syslinux-common syslinux-legacy t1utils thermald tk8.6-blt2.5 totem-common usbmuxd vim-runtime vlc-bin vlc-data
vlc-l10n vlc-plugin-notify vlc-plugin-qt vlc-plugin-skins2 vlc-plugin-video-splitter vlc-plugin-visualization wayland-protocols whoopsie-preferences x11-apps
x11-session-utils x11-xkb-utils x11proto-composite-dev x11proto-damage-dev x11proto-fixes-dev x11proto-randr-dev x11proto-record-dev x11proto-xf86vidmode-dev
x11proto-xinerama-dev xbitmaps xbrlapi xfonts-base xfonts-encodings xfonts-scalable xfonts-utils xinit xinput xml-core xserver-common xserver-xephyr
xserver-xorg-legacy-hwe-18.04 xwayland zeitgeist-core
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libbrotli-dev libc-dev-bin libc6 libc6-dbg libc6-dev libc6-i386 libfreetype-dev libfreetype6 libfreetype6-dev libgnutls30 libgsm1 libharfbuzz0b libhogweed6
liblcms2-2 libnettle8 libp11-kit0 libsdl2-2.0-0 libssh-gcrypt-4 libtasn1-6 libva-drm2 libva-wayland2 libva-x11-2 libva2 libvulkan1 p11-kit-modules
timgm6mb-soundfont zlib1g zlib1g-dev
Suggested packages:
glibc-doc freetype2-doc gnutls-bin fluid-soundfont-gm fluidsynth timidity musescore
Recommended packages:
mesa-vulkan-drivers | vulkan-icd
The following packages will be REMOVED:
alsa-base alsa-utils apache2 apparmor apport apport-gtk aptdaemon aptitude apturl apturl-common aspell aspell-en bluez bluez-cups brltty cheese cmake colord
command-not-found cuda cuda-11-4 cuda-demo-suite-11-4 cuda-drivers cuda-drivers-470 cuda-runtime-11-4 cups cups-browsed cups-core-drivers cups-daemon
dbus-user-session deepstream-6.0 deja-dup dh-python dstat eog evolution-data-server fdisk ffmpeg firefox foomatic-db-compressed-ppds friendly-recovery fuse gdb
gdisk gdm3 gedit gedit-common gir1.2-gst-rtsp-server-1.0 gir1.2-ibus-1.0 gir1.2-peas-1.0 gir1.2-rb-3.0 gir1.2-totem-1.0 gnome-bluetooth gnome-control-center
gnome-disk-utility gnome-initial-setup gnome-keyring gnome-menus gnome-online-accounts gnome-power-manager gnome-session-bin gnome-settings-daemon gnome-shell
gnome-software gnome-software-plugin-snap gnome-startup-applications gnome-terminal gnome-todo gnome-video-effects gnupg gpg-agent gpg-wks-client gpg-wks-server
gstreamer1.0-packagekit gstreamer1.0-plugins-good gvfs gvfs-backends gvfs-daemons gvfs-fuse hplip hplip-data htop ibus ibus-table iio-sensor-proxy
indicator-stickynotes init initramfs-tools initramfs-tools-core irqbalance language-selector-common language-selector-gnome libaa1 libatk-bridge2.0-dev
libatk1.0-dev libatspi2.0-dev libavdevice57 libblockdev-crypto2 libblockdev-part2 libboost-all-dev libboost-iostreams-dev libboost-iostreams1.65-dev
libboost-mpi-python-dev libboost-mpi-python1.65-dev libboost-mpi-python1.65.1 libboost-python-dev libboost-python1.65-dev libboost-regex-dev libboost-regex1.65-dev
libcaca0 libcairo2-dev libcheese-gtk25 libcheese8 libcwidget3v5 libgdk-pixbuf2.0-dev libglib2.0-dev libglib2.0-dev-bin libgstreamer-plugins-base1.0-dev
libgstreamer1.0-dev libgstrtspserver-1.0-0 libgstrtspserver-1.0-dev libgtk-3-dev libgtk2.0-dev libharfbuzz-dev libicu-dev libicu-le-hb-dev libjson-glib-dev
libncurses5 libncurses5-dev libncursesw5 libncursesw5-dev libnss-systemd libopencv-contrib-dev libopencv-contrib3.2 libopencv-dev libopencv-viz-dev libopencv-viz3.2
libopencv3.2-java libopencv3.2-jni libpam-systemd libpango1.0-dev libpeas-1.0-0 libpython-all-dev libpython-dev libpython-stdlib libpython2.7 libpython2.7-dev
libpython2.7-stdlib libpython3-dev libpython3-stdlib libpython3.6 libpython3.6-dev libpython3.6-stdlib libreadline-gplv2-dev librhythmbox-core10 libsane1
libsdl-image1.2 libsdl1.2debian libsmbclient libtinfo-dev libtotem0 libvolume-key1 libvtk6.3 llvm-6.0-dev lsb-release media-player-info mercurial mercurial-common
mount mtr-tiny mutter nano nautilus nautilus-extension-gnome-terminal nautilus-share netplan.io network-manager network-manager-config-connectivity-ubuntu
network-manager-gnome network-manager-pptp network-manager-pptp-gnome networkd-dispatcher nplan ntfs-3g nvidia-driver-470 nvidia-prime nvidia-settings
openjdk-11-jdk openjdk-11-jdk-headless openjdk-11-jre openjdk-11-jre-headless openjdk-8-jdk openjdk-8-jdk-headless openjdk-8-jre openjdk-8-jre-headless
openprinting-ppds openssh-server orca packagekit packagekit-tools pinentry-curses pinentry-gnome3 plymouth plymouth-label plymouth-theme-ubuntu-logo
plymouth-theme-ubuntu-text policykit-1 ppp pppconfig pppoeconf pptp-linux printer-driver-foo2zjs printer-driver-foo2zjs-common printer-driver-gutenprint
printer-driver-hpcups printer-driver-m2300w printer-driver-postscript-hp printer-driver-ptouch printer-driver-pxljr printer-driver-splix procps
pulseaudio-module-bluetooth pyflakes pyflakes3 pylint python python-alabaster python-all python-all-dev python-asn1crypto python-astroid python-babel
python-backports-abc python-backports-shutil-get-terminal-size python-backports.functools-lru-cache python-bleach python-certifi python-cffi-backend python-chardet
python-cloudpickle python-concurrent.futures python-configparser python-crypto python-cryptography python-dateutil python-dbus python-decorator python-dev
python-docutils python-egenix-mxdatetime python-egenix-mxtools python-entrypoints python-enum34 python-funcsigs python-functools32 python-gi python-gi-dev
python-gobject python-gobject-2 python-html5lib python-idna python-imagesize python-ipaddress python-ipykernel python-ipython python-ipython-genutils python-isort
python-jedi python-jinja2 python-jsonschema python-jupyter-client python-jupyter-core python-keyring python-keyrings.alt python-lazy-object-proxy
python-logilab-common python-markupsafe python-mccabe python-mistune python-mock python-nbconvert python-nbformat python-numpy python-numpydoc python-olefile
python-openssl python-pandocfilters python-parso python-pathlib2 python-pbr python-pexpect python-pickleshare python-pil python-pip python-pkg-resources
python-prompt-toolkit python-psutil python-ptyprocess python-pycodestyle python-pyflakes python-pygments python-pyqt5 python-pyqt5.qtmultimedia
python-pyqt5.qtopengl python-pyqt5.qtsvg python-pyqt5.qtwebkit python-qtawesome python-qtconsole python-qtpy python-requests python-roman python-rope python-scandir
python-secretstorage python-setuptools python-simplegeneric python-singledispatch python-sip python-six python-sphinx python-sphinx-rtd-theme python-spyder
python-svn python-talloc python-testpath python-tk python-tornado python-traitlets python-typing python-tz python-urllib3 python-wcwidth python-webencodings
python-wheel python-wrapt python-xdg python-zmq python2.7 python2.7-dev python3 python3-apport python3-apt python3-aptdaemon python3-aptdaemon.gtk3widgets
python3-asn1crypto python3-brlapi python3-cairo python3-certifi python3-cffi-backend python3-chardet python3-click python3-colorama python3-commandnotfound
python3-crypto python3-cryptography python3-cups python3-cupshelpers python3-dateutil python3-dbus python3-debconf python3-debian python3-defer python3-dev
python3-distro-info python3-distupgrade python3-distutils python3-gdbm python3-gi python3-gi-cairo python3-gst-1.0 python3-httplib2 python3-idna python3-keyring
python3-keyrings.alt python3-launchpadlib python3-lazr.restfulclient python3-lazr.uri python3-lib2to3 python3-libnvinfer python3-libnvinfer-dev python3-louis
python3-macaroonbakery python3-mako python3-markupsafe python3-nacl python3-netifaces python3-numpy python3-oauth python3-olefile python3-opencv python3-pexpect
python3-pil python3-pip python3-pkg-resources python3-problem-report python3-protobuf python3-ptyprocess python3-pyatspi python3-pyflakes python3-pymacaroons
python3-renderpm python3-reportlab python3-reportlab-accel python3-requests python3-requests-unixsocket python3-rfc3339 python3-secretstorage python3-setuptools
python3-simplejson python3-six python3-software-properties python3-speechd python3-systemd python3-tz python3-uno python3-update-manager python3-urllib3
python3-virtualenv python3-wadllib python3-wheel python3-xdg python3-xkit python3-yaml python3-zope.interface python3.6 python3.6-dev rhythmbox
rhythmbox-plugin-alternative-toolbar rhythmbox-plugins rtkit samba-libs sane-utils screen-resolution-extra seahorse simple-scan snapd snapd-xdg-open
software-properties-common software-properties-gtk spyder ssh-import-id system-config-printer system-config-printer-common system-config-printer-udev systemd
systemd-sysv sysvinit-utils the totem totem-plugins ubuntu-advantage-tools ubuntu-desktop ubuntu-drivers-common ubuntu-minimal ubuntu-release-upgrader-core
ubuntu-release-upgrader-gtk ubuntu-session ubuntu-software ubuntu-standard ubuntu-system-service udev udisks2 ufw unattended-upgrades update-manager
update-manager-core update-notifier update-notifier-common upower usb-creator-common usb-creator-gtk util-linux vim virtualenv vlc vlc-plugin-base vlc-plugin-samba
vlc-plugin-video-output whoopsie xdg-desktop-portal xdg-desktop-portal-gtk xorg xserver-xorg-core-hwe-18.04 xserver-xorg-hwe-18.04 xserver-xorg-input-all-hwe-18.04
xserver-xorg-input-libinput-hwe-18.04 xserver-xorg-input-wacom-hwe-18.04 xserver-xorg-video-all-hwe-18.04 xserver-xorg-video-amdgpu-hwe-18.04
xserver-xorg-video-ati-hwe-18.04 xserver-xorg-video-fbdev-hwe-18.04 xserver-xorg-video-intel-hwe-18.04 xserver-xorg-video-nouveau-hwe-18.04
xserver-xorg-video-nvidia-470 xserver-xorg-video-qxl-hwe-18.04 xserver-xorg-video-radeon-hwe-18.04 xserver-xorg-video-vesa-hwe-18.04
xserver-xorg-video-vmware-hwe-18.04 zoneminder zoneminder-doc
The following NEW packages will be installed:
libbrotli-dev libfreetype-dev libhogweed6 libnettle8 timgm6mb-soundfont
The following packages will be upgraded:
libc-dev-bin libc6 libc6-dbg libc6-dev libc6-i386 libfreetype6 libfreetype6-dev libgnutls30 libgsm1 libharfbuzz0b liblcms2-2 libp11-kit0 libsdl2-2.0-0
libssh-gcrypt-4 libtasn1-6 libva-drm2 libva-wayland2 libva-x11-2 libva2 libvulkan1 p11-kit-modules zlib1g zlib1g-dev
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
fdisk libncursesw5 (due to fdisk) init systemd-sysv (due to init) mount util-linux (due to mount) sysvinit-utils
23 upgraded, 5 newly installed, 500 to remove and 95 not upgraded.
1 not fully installed or removed.
Need to get 23.5 MB of archives.
After this operation, 2,986 MB disk space will be freed.
