I need to change a single line in the file /opt/google/chrome/google-chrome
exec -a "$0" "$HERE/chrome" "$@"
to
exec -a "$0" "$HERE/chrome" "$@" --test-type --no-sandbox
So my command is:
sed -i 's/exec -a "$0" "$HERE/chrome" "$@"/exec -a "$0" "$HERE/chrome" "$@" --test-type --no-sandbox/' /opt/google/chrome/google-chrome
Which returns:
sed: -e expression #1, char 37: unknown option to `s'
I have searched and found that characters in the command are confusing sed, but I can't seem to find an answer to which ones or how to form it properly. Can anyone help me to edit my command to the proper syntax?
Instead of s/pattern/replace/ use something like s!pattern!replace! (or a different character if you don't like !) -- this is because both the pattern and replacement string contain the / character.
Your sed command is
  • the pattern is exec -a "$0" "$HERE,
  • the replacement is chrome" "$@"
  • and then the flags (s/re/repl/flags) are exec
    • there is an e flag, but x and c are not recognized.
Also note that $ is a special character in a recular expression, and it needs to be escaped.
Try this:
s!exec -a "\$0" "\$HERE/chrome" "\$@"!&  --test-type --no-sandbox!
  • & in the replacement string is replaced with the text that matched the pattern
Alternately, for lines that match "exec ... chrome ...", add the flags to the end of the line:
\!exec -a "\$0" "\$HERE/chrome" "\$@"! s/$/ --test-type --no-sandbox/
glenn jackman
  • 18,218
Yes, thank you. What worked for me is:
sed -i 's!exec -a "$0" "$HERE/chrome" "$@"!exec -a "$0" "$HERE/chrome" "$@" --test-type --no-sandbox'! /opt/google/chrome/google-chrome
