I don't know if this is relevant, but a few weeks ago, I updated my ubuntu from (if my recollection is correct) 20.04 to 22.04 as I was prompted to do by the OS.
On my Laptop, I have both an ubuntu distribution and a windows distribution installed.
So I usually get a GRUB menu when I start my Laptop where I have the following options:
- Ubuntu
- Advanced options for Ubuntu
- Windows Boot Manager (on /dev/nvme0n1p1)
- UEFI Firmware Settings
Today, my ubuntu won't boot up anymore. When I start my laptop, I get the GRUB menu (as usual) but when I choose to start ubuntu, I get stuck in the loading screen, depicting the manufacturer logo (HP). Sometimes not even that and I get stuck in the boot-up prompt where it shows me the steps taken for the boot up. The Windows boot works normally.
I tried to go to Advanced options for Ubuntu. There I got the following options:
- Ubuntu, with Linux 5.15.0-47-generic
- Ubuntu, with Linux 5.15.0-47-generic (recovery mode)
- Ubuntu, with Linux 5.4.0-125-generic
- Ubuntu, with Linux 5.4.0-125-generic (recovery mode)
I tried to start with 5.4.0.125 but the same thing happens.
I started recovery mode. That sometomes gets stuck in A start Job is running for Network Time Synchronization. At which point I usually force restart with the power-off button. It should also be noted, that I dont have a stable internet connection, because I just moved. Im not sure if my laptop is connected to my wifi, because I had to reconnect my other devices. And it doesnt have an ethernet plug, so I basically have to get my system running offline or somehow connect the wifi while it is in this "unbootable" state.
When I finally got through after 1-2 restarts, I tried the following options:
- dpkg
- fsck
- root
The first two didnt fix the problem. Either it finished and nothing changed or got stuck at some point (waited about 15 minutes for every step there).
I am able to use "root" to get my prompt, however, I dont even know where to start there to fix the problem. I can't even run sudo apt update/upgrade, because I'm not connected to the internet.
I even tried to check for my wifi net in the "root" prompt and used ifconfig but there was nothing and when I just used ifconfig wlan0 it told me there is no such device.
I found this and wanted to
Reinstall Ubuntu While Keeping Files and Programs
So I followed this guide, installed Rufus on my other laptop and created a Ubuntu Live-USB. When I try to boot from USB, I again get a GRUB prompt. This one looks a little different (lower resolution) and has the option to "boot from next volume". Which leads me to the original GRUB prompt described above. So this indicates to me, that I am correctly booting from the USB-Stick. These are the options on the GRUB:
- Try or install Ubuntu
- Ubuntu (safe graphics)
- OEM install (for manufacturers)
- Boot from next volume
However, when I choose Try or install Ubuntu or `Ubuntu (safe graphics)", the exact same thing happens. Which is odd, because as I understand it, this should be a newly installed working system independent of the old broken one.
I sadly don't know enough about ubuntu or linux to fix this myself or even know which next step to take. And since the live USB doesn't seem to work either, and the system didn't react to a USB stick with the .iso on it, I don't even know how to reinstall my system. That being said, the goal is to not fully delete evrything anyway, but rather to somehow repair Ubuntu or at least reinstall it so that my other data stays intact.
One more thing I at least got to figure out is how to get to my boot parameters for the GRUB option Ubuntu from the first/original GRUB, which I tried to type out here:
setparams 'Ubuntu'
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root (uuid)
linux /boot/vmlinuz-5.15.0-47-generic root=UUID=(uuid) ro quiet splash $vt_handoff
initrd /boot/initrd.img-5.15.0-47-generic
Update
As suggested in the comments, I tried the Live-USB on another Laptop and it worked.
So to summarize:
Defect Laptop:
- Ubuntu partition doesn't work
- Ubuntu Live-USB doesn't work
- Windows partition works
Other Laptop:
- Ubuntu Live-USB works
I don't understand this. If it was a hardware defect, I would expect the Windows partition to also not work. It it was a software defect, Id expect the Live-USB to not work on the other device. This feels contradictory. Id be very happy about any explanation or suggestion that could lead me to solve this problem.
