I have Ubuntu installed in an USB drive. It is not a live or persistent live install. It is a regular, full install.
Is there any way to backup the USB drive to a .img or .iso file, which I can later use to restore a bootable version of Ubuntu to this USB drive or another USB drive?
Note that this is a simplistic method, that will create large files already for "small" devices.
Backup:
  1. use e.g. lsblk -ape7 to find out which /dev/... you have the USB drive positioned at
    (e.g /dev/sdc to have a true dev to show below).
  2. make sure the drive is NOT mounted
  3. Open a terminal, type
    sudo dd if=/dev/sdc bs=128k | gzip --best >/place/to/store/backup.img.gz
  4. hit Enter and fill in the (root) password
Restore:
The example /dev/sdc needs to be same-size USB drive, or larger than the backup source.
Also: Make sure /dev/sdc is the CORRECT device,
all earlier content will be lost and will NOT be recoverable.
Enter gzip -c /place/to/store/backup.img.gz | sudo dd of=/dev/sdc bs=128k
in a terminal (at the bash prompt) and provide the requested input (root password).
Additional options to dd (notrunc, noerror) and gzip might be in place.
Options:
The image file produced by dd, when uncompressed (and at least of some common content types), may be mounted as a loop device:
lodev=$(losetup -f) - will create a device, if possible, and keep the name in $lodev
sudo losetup $lodev imagefile - will attempt to use the imagefile, create a 'removable' disk and mount the partitions in it.
sudo losetup -d $lodev - will dismount the image, and deconstruct the loop device.
Hannu
  • 6,605
  • 28
  • 45
