I did the fresh ubuntu 22.04 installation on OMEN by HP 16.1 inch Gaming Laptop 16-k0000 (594K2AV) laptop.
And I found that the Audio is not working, 3.5 mm jack is also not working.
I tried with Ubuntu 18.04 LTS as well, but getting the same issue.
Kindly provide the best solution for the same.
Thanks in Advance
First, try running $ pulseaudio --start ,this should enable sound. If not:
Test the current situation with default output.
$ speaker-test
See other available sound outputs.
$ aplay -l
Pick other outputs then try them.
$ speaker-test -D hw:<card id>,<device id>
For example, if the output of aplay contains a line
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Then the command to try this output will be
$ speaker-test -D hw:1,7
Kill all pulse audio daemons to prevent them from interfering during the troubleshooting.
$ mv ~/.config/pulse ~/.config/pulse_old # Remove potentially corrupted pulse files
$ sudo killall pulseaudio
Try step 1, 2, and 3 again.
Check dmesg and journalctl to see if any errors regarding the sound are reported.
This link may also be of use: After ubuntu 19.04 update, sound card cannot be detected
