When I enter the following:
echo "This is for testing" | tr -s [:space:]
I get this:
This is for testing
I was hoping to remove the multiple spaces and just have one space between the words. I don't see what I am doing wrong.
I get this:
This is for testing
In tr -s [:space:], the unquoted [:space:] will be treated by the shell as a glob, and if you a file that matches that glob (a filename with a single character of any of :, a, c, e, p, s), then your shell (likely bash) will expand that glob to that filename:
bash-5.1$ echo tr -s [:space:]
tr -s [:space:]
bash-5.1$ touch c
tr -s c
(It might also do other things based on shell options.)
So, use quoting so that the shell doesn't interpret [:space:]:
echo "This is for testing" | tr -s '[:space:]'
It works for me in squeezing the spaces, maybe it doesn't work for you because those spaces in your sample text aren't really spaces,
They could be tabs
Try this
echo "This is for testing" | tr \\t " "
or, if there are multiple tabs you can try using
echo "This is for testing" | tr \\t " " | tr -s [:space:]
