[enter image description here]
1Failed to connect to repository : Command "git ls-remote -h -- git@github.com:yeni/jenkins-terraform.git HEAD" returned status code 128: stdout: stderr: No ECDSA host key is known for github.com and you have requested strict checking. Host key verification failed. fatal: Could not read from remote repository.
Please make sure you have the correct access rights and the repository exists.
i am getting this error when I try to connect GitHub repo with Jenkins. Let me know how to solve it
issue image
user2631106
  • 61
... and you have requested strict checking.
You can check the Jenkins/Git-Host-Key-Verification setting under Global Security...
Jenkins/Git-Host-Key-Verification-Configuration
Obviously you can workaround it by selecting No verification which is not at all recommended though.
In case you want to use Known hosts file verification, you can pre-populate the SSH keys for each server, using the below command (on Linux)...
ssh-keyscan github.com >> ~/.ssh/known_hosts
You have to do that on the user-account that Jenkins is running with.
There is this similar StackOverflow thread "Jenkins Host key verification failed", where other solutions are mentioned, alongside the above.
idrositis
  • 331
as mentioned in StackOverflow thread "Jenkins Host key verification failed" don't forget to populate the jenkins user's known_hosts file !
Login before any add to the known_hosts using :
sudo su - jenkins
I have run the following command after logging into the Jenkins container as the jenkins user, to get an automated host key entry in the known_hosts file.
ssh -T git@github.com
And that fixed it.
Tonmoy
  • 101
