I have recently got a TP-Link AXE5400 Archer TXE75E WiFi PCIE card. I have a Windows 10, Ubuntu 20.04 Dual Boot System. The cards comes with drivers for Windows which work well. On Ubuntu there are no official drivers, only the Bluetooth antenna is recognized. The WiFi is not detected (No WiFI adapter found). Are there any Ubuntu drivers available online that would be compatible with this card?
lspci -knn | grep Net -A3
outputs:
03:00.0 Network controller [0280]: Intel Corporation Device [8086:2725] (rev 1a)
Subsystem: Intel Corporation Device [8086:0024]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
The command
sudo dmesg | grep iwl
outputs:
[ 3.946374] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 3.958162] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 3.958181] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28
[ 3.958548] iwlwifi 0000:03:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm
[ 4.419879] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.583922] iwlwifi 0000:03:00.0: loaded PNVM version 0x324cd670
[ 4.689765] iwlwifi 0000:03:00.0: Timeout waiting for PNVM load!
[ 4.689770] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 4.689774] iwlwifi 0000:03:00.0: iwl_trans_send_cmd bad state = 1
[ 4.897763] iwlwifi 0000:03:00.0: firmware didn't ACK the reset - continue anyway
[ 4.909541] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
To write this post the computer is connected to my Smartphone WiFi via USB-Hotspot.
