Installation or failed installation caused both of my ssd to become unbootable.
I just got my 1tb nvme drive and installed fresh windows on that. I decided to try out linux and installed ubuntu on my old 250gb sata ssd. I used a usb stick to install the os.
Once i tried to install i chose the option to erase the old 250gb drive and install ubuntu on it. I got an error after it tried to install, right before you select a region on a map. I don't remember what error war thrown(might have something to do with partitions) but i could only ignore or cancel and it was suggesting a reboot before continuing. Once i hit restart it froze and after some minutes i decided to hit reset key. From there i could no longer boot to any disk because there was no drives to boot from according to my bios. Entering bios showed no bootable drives. I decided to carry on with installation and i could chose between 1tb and 250gb drive in installation. I chose the 250gb drive and installed successfully. In ubunto i can see my 1tb drive but i can't boot from it, my bios can only see the 250gb drive now.
Is there a way to make my drive visible to my bios again so i can boot from it or do i have to reinstall windows on it? I guess my second question is how this happened. Why did failed installation make all my drives disappear and why does installing ubuntu on one drive affect other drives? Making it unbootable and recognizable by bios.
https://paste.ubuntu.com/p/XM44pqpFzY/
I was unable to fix/bring back the main disk (disk 0). When the installation of Ubuntu failed it also for some reason f-ed over disk 0 while trying to wipe and install on disk 1. I was unable to reinstall win11 on disk 0 as it threw "Inaccessible Boot Device" Error.
I was able to fix this with windows installer and running diskpart in command prompt with a clean command. No UEFI setting needed to be changed, dual-boot works fine now. Running win11 on disk 0 and Ubuntu on disk 1 as planned.
Thanks to the people in the comments for helping with troubleshooting.
andrew.46
  • 39,359
