What I've Tried:
A github repo imports bpy, so I tried
  1. to build Blender via git clone but the install_deps.sh command fail because it cannot install a requested package, libpystring-dev.
  2. pip install bpy - nope.
  3. This guy's writeup started to get somewhere, but still no recognized bpy module after an ostensibly successful run-through.
Since I need to install Blender in my WSL Ubuntu, I'm not sure else how to do this.
Corresponding Errors:
1. Build Blender via git clone:
 ./blender/build_files/build_environment/install_deps.sh
WARNING! ****WARNING****
If you are experiencing issues building Blender, _*TRY A FRESH, CLEAN BUILD FIRST*_!
The same goes for install_deps itself, if you encounter issues, please first erase everything in /home/domattioli/src/blender-deps and /opt/lib
(provided obviously you did not add anything yourself in those dirs!), and run install_deps.sh again!
Often, changes in the libs built by this script, or in your distro package, cannot be handled simply, so...
You may also try to use the '--build-foo' options to bypass your distribution's packages for some troublesome/buggy libraries...
Ran with: install_deps.sh
Installing dependencies for DEB-based distribution
Source code of dependencies needed to be compiled will be downloaded and extracted into '/home/domattioli/src/blender-deps'. Built libs of dependencies needed to be compiled will be installed into '/opt/lib'. Please edit $SRC and/or $INST variables at the beginning of this script, or use --source/--install options, if you want to use other paths!
Number of threads for building: 24 (automatically detected, use --threads=<nbr> to override it). Full install: false (use --with-all option to enable it). Building OpenCOLLADA: false (use --with-opencollada option to enable it). Building Embree: false (use --with-embree option to enable it). Building OpenImageDenoise: false (use --with-oidn option to enable it).
Example: Full install without OpenCOLLADA: --with-all --skip-opencollada
Use --help to show all available options!
Do you want to continue (Y/n)?y Get:1 file:/var/cuda-repo-wsl-ubuntu-11-7-local InRelease [1575 B] Get:1 file:/var/cuda-repo-wsl-ubuntu-11-7-local InRelease [1575 B] Get:2 file:/var/cudnn-local-repo-ubuntu2004-8.4.1.50 InRelease [1575 B] Get:2 file:/var/cudnn-local-repo-ubuntu2004-8.4.1.50 InRelease [1575 B] Get:3 https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64 InRelease [1484 B] Get:4 https://nvidia.github.io/nvidia-container-runtime/stable/ubuntu18.04/amd64 InRelease [1481 B] Get:5 https://nvidia.github.io/nvidia-docker/ubuntu18.04/amd64 InRelease [1474 B] Hit:6 https://packages.microsoft.com/ubuntu/20.04/prod focal InRelease Hit:7 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 InRelease Hit:8 https://arkane-systems.github.io/wsl-transdebian/apt focal InRelease Get:9 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB] Hit:10 https://developer.download.nvidia.com/compute/cuda/repos/wsl-ubuntu/x86_64 InRelease Hit:11 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu focal InRelease Hit:12 http://archive.ubuntu.com/ubuntu focal InRelease Hit:13 http://archive.canonical.com/ubuntu focal InRelease Get:14 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB] Hit:15 http://ppa.launchpad.net/saiarcot895/chromium-dev/ubuntu focal InRelease Hit:16 http://ppa.launchpad.net/thomas-schiex/blender/ubuntu focal InRelease Get:17 http://archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB] Fetched 340 kB in 1s (399 kB/s) Reading package lists... Done
Reading package lists... Done Building dependency tree Reading state information... Done Note, selecting 'libfontconfig1-dev' instead of 'libfontconfig-dev' E: Unable to locate package libpystring-dev ERROR! apt-get failed to install requested packages, exiting.
2. pip install bpy:
pip install bpy
Collecting bpy
  Using cached bpy-0.0.0a0.tar.gz (19 kB)
    ERROR: Command errored out with exit status 1:
     command: /home/domattioli/miniconda3/bin/python -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-qiee2cmh/bpy_a414fb89254042aa8aa952fca27c77e4/setup.py'"'"'; __file__='"'"'/tmp/pip-install-qiee2cmh/bpy_a414fb89254042aa8aa952fca27c77e4/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-ojmq4blc
         cwd: /tmp/pip-install-qiee2cmh/bpy_a414fb89254042aa8aa952fca27c77e4/
    Complete output (16 lines):
    Traceback (most recent call last):
      File "/home/domattioli/miniconda3/lib/python3.9/tokenize.py", line 342, in find_cookie
        codec = lookup(encoding)
    LookupError: unknown encoding: future_fstrings
During handling of the above exception, another exception occurred:
  File &quot;&lt;string&gt;&quot;, line 1, in &lt;module&gt;
  File &quot;/home/domattioli/miniconda3/lib/python3.9/tokenize.py&quot;, line 394, in open
    encoding, lines = detect_encoding(buffer.readline)
  File &quot;/home/domattioli/miniconda3/lib/python3.9/tokenize.py&quot;, line 381, in detect_encoding
    encoding = find_cookie(second)
  File &quot;/home/domattioli/miniconda3/lib/python3.9/tokenize.py&quot;, line 350, in find_cookie
    raise SyntaxError(msg)
SyntaxError: unknown encoding for '/tmp/pip-install-qiee2cmh/bpy_a414fb89254042aa8aa952fca27c77e4/setup.py': future_fstrings
WARNING: Discarding https://files.pythonhosted.org/packages/bc/e2/20c6d56f1143e13c0fc24a7d987ee28e4949b8edbbbb1b66f705d129bdc5/bpy-0.0.0a0.tar.gz#sha256=b48c0348cccaf9ad316bccd3dc65fdc8422e4c310c79c85448b01ae7feb7f02e (from https://pypi.org/simple/bpy/) (requires-python:>=3.4.0). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output. ERROR: Could not find a version that satisfies the requirement bpy (from versions: 0.0.0a0) ERROR: No matching distribution found for bpy
  1. Github writeup:
domattioli@DSI-8VD8XP3:/usr/include/blender-git/lib/linux_centos7_x86_64/python/bin$ ls
python3.10  python3.7m  python3.9
(base) domattioli@DSI-8VD8XP3:/usr/include/blender-git/lib/linux_centos7_x86_64/python/bin$ python3.9
Python 3.9.12 (main, Apr  5 2022, 06:56:58)
[GCC 7.5.0] :: Anaconda, Inc. on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import bpy
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'bpy'
domattioli
