What is the best and easiest software recommended for creating a custom Ubuntu Live Image that is installable?
There really is no such thing. What you ask here is a task for a backup solution not a custom live session.
I was using Systemback for Ubuntu 16.04 and it was great, but it does not work for Ubuntu versions greater than 16.04.
How about timeshift ? Should do the same as Systemback.
Is there a recommended tool or software that makes it easy to do the above in 2022?
My experience: use a normal live session. Altering a live session is time consuming and is only limited usable. A live session only has a lifespan of a couple of months or years. Plus if you change your mind you need to redo that live session.
My setup:
I have 2 disks: ssd and hdd. My ssd holds / and includes /home/. My hdd holds all the directories that are created in /home/$USER. Every time I reinstall my ssd gets formatted as I have zero personal files on that disk. My hdd gets mounted as /discworld/
I have a script that has a lot of lines and looks like this (1 example of each different options):
# directories set to /discworld/
cp /discworld/Documents/user-dirs.dirs ~/.config/user-dirs.dirs
# apt
apt update
apt install vlc smplayer tweaks
# gsettings
gsettings set org.gnome.settings-daemon.plugins.power lid-close-battery-action 'nothing'
(and so on; if you use it the backup directory could also hold a backup of for instance browser settings, archived mails etc).
During the time I use an Ubuntu version I install more software or test different settings. And each of those installs I add to the script. When I reinstall I remove those I did install but did not use that often.
I even had a time where I had 2 or 3 of those scripts each for a complete different setup.
When a new LTS is released things often change: different defaults, new or deleted gsettings options. Unity that got deleted, systemd got introduced. Or maybe I changed my mind about some software I want as my default. It is far quicker to open this script and alter it.
It has been my method for at least the last 10 years.
