I'm using Ubuntu 20.04 Desktop. When I'm launching Snapstore, nothing happens. This is a new behaviour, worked fine about a week ago.
When I launch it via terminal using
snap-store
It says:
Gtk Failed to load module "canberra-gtk-module"
But when I do (as written here: Failed to load module “canberra-gtk-module” .... but already installed):
sudo apt install libcanberra-gtk-module libcanberra-gtk3-module
it says:
libcanberra-gtk3-module is already the latest version (0.30-7ubuntu1).
libcanberra-gtk-module is already the latest version (0.30-7ubuntu1).
Edit I made a reboot and it says now (additionally to the canberra-gtk-module error):
"Memory access error (memory dump written)"
(might sound a bit different, as I'm using the german version and the message in german is: Speicherzugriffsfehler (Speicherabzug geschrieben)
Wombi Wombyte
  • 121
Look here: https://forum.snapcraft.io/t/snap-store-is-not-starting/31536/13
There's a problem with revision 558 of the snap-store that is currently the stable one. But the bug is fixed in the edge-version (currently 592). So you can try install the edge-version:
sudo snap refresh --edge snap-store
to switch back to stable, once the fixed 592 revision has migrated to stable, you can then run:
sudo snap refresh --stable snap-store
nyx
  • 191
