I am on Ubuntu server 20.04, running LAMP with php7.4-fpm.
I just performed the latest update/upgrade and confirmed everything was working correctly:
● php7.4-fpm.service - The PHP 7.4 FastCGI Process Manager
     Loaded: loaded (/lib/systemd/system/php7.4-fpm.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2022-08-26 00:50:45 CST; 7min ago
       Docs: man:php-fpm7.4(8)
   Main PID: 120871 (php-fpm7.4)
     Status: "Processes active: 0, idle: 2, Requests: 24, slow: 0, Traffic: 0.1req/sec"
      Tasks: 3 (limit: 4380)
     Memory: 80.8M
     CGroup: /system.slice/php7.4-fpm.service
             ├─120871 php-fpm: master process (/etc/php/7.4/fpm/php-fpm.conf)
             ├─120892 php-fpm: pool www
             └─120893 php-fpm: pool www
Then several minutes later... my Nextcloud installation suddenly stops syncing, so I re-check the status of php-fpm and I get:
     Loaded: masked (Reason: Unit php7.4-fpm.service is masked.)
     Active: inactive (dead) since Fri 2022-08-26 01:07:14 CST; 5min ago
   Main PID: 120871 (code=exited, status=0/SUCCESS)
     Status: "Processes active: 0, idle: 2, Requests: 44, slow: 0, Traffic: 0req/sec"
Aug 26 01:07:14 admin.example.com systemd[1]: Stopping The PHP 7.4 FastCGI Process Manager... Aug 26 01:07:14 admin.example.com systemd[1]: php7.4-fpm.service: Succeeded. Aug 26 01:07:14 admin.example.com systemd[1]: Stopped The PHP 7.4 FastCGI Process Manager. Warning: journal has been rotated since unit was started, output may be incomplete.`
And, quite lierally, /lib/systemd/system/php7.4-fpm.service no longer exists
# stat /lib/systemd/system/php7.4-fpm.service
stat: cannot stat '/lib/systemd/system/php7.4-fpm.service': No such file or directory
I checked syslog to see what was happening when the service was masked according to the timestamp... and there is simply nothing in the log to explain what's happening:
Aug 26 01:07:14 admin systemd[1]: Stopped The PHP 7.4 FastCGI Process Manager.
Aug 26 01:07:14 admin systemd[1]: php7.4-fpm.service: Succeeded.
Aug 26 01:07:14 admin systemd[1]: Stopping The PHP 7.4 FastCGI Process Manager...
Aug 26 01:07:14 admin systemd[1]: Configuration file /etc/systemd/system/gitea.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
Aug 26 01:07:14 admin systemd[1]: Reloading.
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module readline for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module pspell for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module ctype for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module redis for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module dom for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module soap for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module iconv for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module apcu_bc for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module phar for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module mysqlnd for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module imap for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module xsl for PHP 7.4 fpm sapi
Aug 26 01:07:14 admin php7.4-fpm: php_invoke prerm: Disabled module sysvshm for PHP 7.4 fpm sapi
Update: When I attempt to unmask php7.4-fpm using systemctl unmask php7.4-fpm, two things happen:
  1. /etc/systemd/system/php7.4-fpm.service is removed. /etc/systemd/system/php7.4-fpm.service is a symlink to /dev/null
  2. php7.4-fpm.service is started using init.d
● php7.4-fpm.service - LSB: starts php7.4-fpm
     Loaded: loaded (/etc/init.d/php7.4-fpm; generated)
     Active: active (exited) since Fri 2022-08-26 09:09:10 CST; 6min ago
       Docs: man:systemd-sysv-generator(8)
      Tasks: 0 (limit: 4380)
     Memory: 0B
If I try to reinstall php7.4fpm using apt-get install --reinstall php7.4-fpm I get:
root@admin:~# apt-get install --reinstall php7.4-fpm
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: php7.4-fpm : Depends: php7.4-common (= 7.4.3-4ubuntu2.12) but 7.4.3-4ubuntu2.13 is to be installed E: Unable to correct problems, you have held broken packages.
All of the above steps are based upon this post: systemctl, how to unmask
I am currently stuck with broken packages
Yes, I have tried:
apt install -f
dpkg --configure -a
Nothing is helping.. Yes... I read this post while troubleshooting.... the repo is just broken Unable to correct problems, you have held broken packages
sotirov
  • 4,379
nightwatch
  • 805
  • 23
  • 51
This problem fundamentally seems to be a packaging problem with the upstream ubuntu repos that maintainers probably need some time to address.
In the meanwhile, the one and only solution to this problem seems to be that -before- you do the latest php update... ensure that you have this repo installed on your machine:
sudo add-apt-repository ppa:ondrej/php
If this repo is installed before your update, you can avoid the nightmare above.
nightwatch
  • 805
  • 23
  • 51
