Main problem
Wifi does not even show up as an network option after multiple reboots and driver installations -> iwconfig returns nothing lshw returns this:
~$ sudo lshw -C network
*-network UNCLAIMED
description: Network controller
product: Realtek Semiconductor Co., Ltd.
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: ioport:2000(size=256) memory:80900000-809fffff
System information
Wifi card info
lspci -knn | grep Net -A3; rfkill list
pcilib: Error reading /sys/bus/pci/devices/0000:00:08.3/label: Operation not permitted
01:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b852]
Subsystem: Lenovo Device [17aa:4853]
02:00.0 SD Host controller [0805]: O2 Micro, Inc. SD/MMC Card Reader Controller [1217:8621] (rev 01)
Subsystem: O2 Micro, Inc. SD/MMC Card Reader Controller [1217:0002]
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
According to the command output above, my device has Realtek 10ec:b852 wifi + bluetooth combo card. WirelessCat says that this card should work with rtw89 driver
Neofetch
Why is the kernel 6.0
On this particular lenovo keyboard didnt work unless i used the latest available daily kernel from ubuntu, mainline unfortunately didnt provide it either.
What drivers I've tried
Both were installed exactly as per the github instructions. I did not try them both at the same time. When i switched between them i uninstalled one and then rebooted before installing the other one.
I installed drivers without secure boot which is currently completely disabled along with all other bios security features(i triple checked) Installations on both drivers were successful to the best of my knowledge and running
sudo modprobe -vr 8852be
sudo modprobe -v 8852be
returned no errors either.
modinfo 8852be shows the available options for the driver
Similar posts that did not help
- https://www.reddit.com/r/pop_os/comments/w0txaa/no_wifi_on_lenovo_yoga_6_13/
- wifi Adapter not found realtek RTL8852BE WiFi 6 802.11ax PCIe in ubuntu 22.04
EDIT: Tried installing Manjaro to take the drivers from it, same problem
Thank you for reading this far. I hope i provided all the necessary information.
