I have the same issue as this person. Just upgraded my Xubuntu, and got those messages during the upgrade - and, now when I try to install the updates for those packages, it doesn't work. I found an error log:
DKMS make.log for nvidia-470.141.03 for kernel 5.15.0-46-generic (x86_64)
Fri Aug 19 12:06:32 PM MDT 2022
make[2]: Entering directory '/usr/src/linux-headers-5.15.0-46-generic'
arch/x86/Makefile:142: CONFIG_X86_X32 enabled but no binutils support
make[2]: /usr/bin/gcc: No such file or directory
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0
You are using:
make -f ./scripts/Makefile.build obj=/var/lib/dkms/nvidia/470.141.03/build \
single-build= \
need-builtin=1 need-modorder=1
The C compiler '/usr/bin/gcc' does not appear to be able to
create object files. Please make sure you have
your Linux distribution's libc development package
installed and that '/usr/bin/gcc' is a valid C compiler
name.
*** Failed CC sanity check. Bailing out! ***
make[2]: *** [/var/lib/dkms/nvidia/470.141.03/build/Kbuild:194: cc_sanity_check] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile:1881: /var/lib/dkms/nvidia/470.141.03/build] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-5.15.0-46-generic'
make: *** [Makefile:80: modules] Error 2
This is for one of the processes that tried to run after it installs, or fails to install, the NIh libraries.
Using apt-cache policy as recommended in one of the comments on the previous question, I see all sources for Jammy, none for Bionic.
Additionally, I am now having an issue with my display - it won't let me change the resolution, staying stubbornly stuck at 1024x768. I assume this is because it can't update the nvidia drivers or something, but it's hard to be sure.
