I freshly installed Ubuntu 22.04 and I have two Linux kernels in GRUB menu/Advanced options: 5.15.0-43-generic and 5.15.0-46-generic.
By default, it tries to boot the newer one, but that crashes on this error:
not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
I have to choose the older one to get it start.
My notebook: Dell XPS 9370
I use ZFS with the encryption from Ubuntu installer.
I've tried https://askubuntu.com/a/41939/1623974, but that didn't work for me.
Under /boot I have:
  1. initrd.img -> initrd.img-5.15.0-46-generic
  2. initrd.img.old -> initrd.img-5.15.0-43-generic
  3. and similiar symlinks for vmlinuz*
EDIT:
user@computer:~$ sudo update-grub
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: vmlinuz-5.15.0-46-generic in rpool/ROOT/ubuntu_2zhbmp
Found initrd image: initrd.img-5.15.0-46-generic in rpool/ROOT/ubuntu_2zhbmp
Found linux image: vmlinuz-5.15.0-43-generic in rpool/ROOT/ubuntu_2zhbmp
Found initrd image: initrd.img-5.15.0-43-generic in rpool/ROOT/ubuntu_2zhbmp
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
user@computer:~$ dpkg --list | grep linux-image ii linux-image-5.15.0-43-generic 5.15.0-43.46 amd64 Signed kernel image generic ii linux-image-5.15.0-46-generic 5.15.0-46.49 amd64 Signed kernel image generic ii linux-image-generic 5.15.0.46.46 amd64 Generic Linux kernel image ii linux-image-generic-hwe-22.04 5.15.0.46.46 amd64 Generic Linux kernel image
EDIT2:
I've deleted 5.15.0-46 version, but when I try to do dist-upgrade or full-upgrade, it doesn't show any available updates.
Thanks for any help!
John Doe
Grub will take responsibility to tell which kernel image, initrd image are used to boot. So you need to change the option of grub config in this file "/boot/grub/grub.cfg".
        menuentry 'Ubuntu, with Linux 5.15.0-46-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.0-46-generi
c-advanced-6c8f350d-4e7c-4841-98e5-15ca9d43ef32' {
                recordfail
                load_video
                gfxmode $linux_gfx_mode
                insmod gzio
            echo    'Loading Linux 5.15.0-46-generic ...'
            linux   /boot/vmlinuz-5.15.0-46-generic root=UUID=6c8f350d-4e7c-4841-98e5-15ca9d43ef32 ro  quiet splash $vt_handoff
            echo    'Loading initial ramdisk ...'
            initrd  /boot/initrd.img-5.15.0-46-generic
Option initrd default not load from your initrd.img, so you need to change initrd name from initrd.img-5.15.0-46-generic to initrd.img .
Hope that will help.
