I do everything like said in the guide but I get
The guide that I used: https://docs.docker.com/desktop/install/ubuntu/
user@pc:~/Downloads$ sudo apt-get install docker-ce docker-ce-cli containerd.io docker-compose-plugin
Reading package lists... Done
Building dependency tree... Done
Package docker-ce is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package docker-ce-cli is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package 'docker-ce' has no installation candidate E: Package 'docker-ce-cli' has no installation candidate E: Unable to locate package containerd.io E: Couldn't find any package by glob 'containerd.io' E: Couldn't find any package by regex 'containerd.io' E: Unable to locate package docker-compose-plugin
When I try installing dependencies I get these errors
user@pc:~/Downloads$  sudo apt install lsb-release ca-certificates apt-transport-https software-properties-common -y
ca-certificates is already the newest version (20211016).
lsb-release is already the newest version (11.1.0ubuntu4).
software-properties-common is already the newest version (0.99.22.3).
software-properties-common set to manually installed.
You might want to run 'apt --fix-broken install' to correct these.
 docker-desktop : Depends: qemu-system-x86 (>= 5.2.0) but it is not going to be installed
                  Depends: docker-ce-cli but it is not installable
                  Depends: pass but it is not going to be installed
                  Depends: uidmap
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
When I install docker I get this:
user@pc:~/Downloads$ echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
user@pc:~/Downloads$ sudo apt update Hit:1 http://ua.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://ua.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://ua.archive.ubuntu.com/ubuntu jammy-backports InRelease
Get:4 https://download.docker.com/linux/ubuntu jammy InRelease [48,9 kB]
Get:5 http://dl.google.com/linux/chrome/deb stable InRelease [1 811 B]
Get:6 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Ign:7 https://ppa.launchpadcontent.net/rock-core/qt4/ubuntu jammy InRelease
Hit:8 https://repo.skype.com/deb stable InRelease
Get:9 https://download.docker.com/linux/ubuntu jammy/stable amd64 Packages [6 255 B] Err:5 http://dl.google.com/linux/chrome/deb stable InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B Err:10 https://ppa.launchpadcontent.net/rock-core/qt4/ubuntu jammy Release
404 Not Found [IP: 185.125.190.52 443] Ign:11 http://linux.dropbox.com/ubuntu disco InRelease
Get:12 http://linux.dropbox.com/ubuntu disco Release [6 598 B] Get:13 http://security.ubuntu.com/ubuntu jammy-security/main amd64 DEP-11 Metadata [11,4 kB] Get:14 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 DEP-11 Metadata [10,1 kB] Get:15 http://linux.dropbox.com/ubuntu disco Release.gpg [473 B]
Get:16 http://linux.dropbox.com/ubuntu disco/main amd64 Packages [1 169 B] Get:17 http://linux.dropbox.com/ubuntu disco/main i386 Packages [1 163 B] Reading package lists... Done
W: GPG error: http://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 4EB27DB2A3B88B8B E: The repository 'http://dl.google.com/linux/chrome/deb stable InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'https://ppa.launchpadcontent.net/rock-core/qt4/ubuntu jammy Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. W: https://repo.skype.com/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details. W: http://linux.dropbox.com/ubuntu/dists/disco/Release.gpg: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
user@pc:~/Downloads$ sudo apt install docker-ce Reading package lists... Done Building dependency tree... Done Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: docker-ce : Depends: containerd.io (>= 1.4.1) but it is not going to be installed Depends: docker-ce-cli but it is not going to be installed Recommends: docker-ce-rootless-extras but it is not going to be installed Recommends: pigz but it is not going to be installed docker-desktop : Depends: qemu-system-x86 (>= 5.2.0) but it is not going to be installed Depends: docker-ce-cli but it is not going to be installed Depends: pass but it is not going to be installed Depends: uidmap E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
What do I do please help!
karel
  • 122,292
  • 133
  • 301
  • 332
mevsme
  • 561
this problem is answered by docker it self check this page you can Install the plugin manually
To download and install the Compose CLI plugin, run:
 DOCKER_CONFIG=${DOCKER_CONFIG:-$HOME/.docker}
 mkdir -p $DOCKER_CONFIG/cli-plugins
 curl -SL https://github.com/docker/compose/releases/download/v2.12.2/docker-compose-linux-x86_64 -o $DOCKER_CONFIG/cli-plugins/docker-compose
This command downloads the latest release of Docker Compose (from the Compose releases repository) and installs Compose for the active user under $HOME directory.
To install:
Docker Compose for all users on your system, replace ~/.docker/cli-plugins with /usr/local/lib/docker/cli-plugins. A different version of Compose, substitute v2.12.2 with the version of Compose you want to use. Apply executable permissions to the binary:
 chmod +x $DOCKER_CONFIG/cli-plugins/docker-compose
or, if you chose to install Compose for all users:
 sudo chmod +x /usr/local/lib/docker/cli-plugins/docker-compose
Test the installation.
 docker compose version
Jeffery White
  • 221
You can try:
sudo pip3 install docker-compose
It helps in my case
sosnus
  • 139
