I have tried removing the 5.17.0-1014 kernel with the command:
sudo apt remove linux-image-5.17.0-1014-oem
And apt suggests to install linux-image-unsigned-5.17.0-1014-oem.
To remove the kernel I have typed the command:
sudo apt remove linux-image-5.17.0-1014-oem linux-image-unsigned-5.17.0-1014-oem
Is it normal behavior of apt?
Mahler
  • 739
I've found similar older question Removing linux-image kernel causes linux-image-unsigned package to be installed
I like answer from @t7e https://askubuntu.com/a/1418845/764841 it worked for me.
It seemed not obvious, but quite a simple solution - just remove them both in one command:
sudo apt-get remove --purge linux-image-4.18.0-15-generic linux-image-unsigned-4.18.0-15-generic
VasekCh
  • 221
This issue was fixed by system update. It works normally presently.
sudo apt remove linux-modules
sudo apt remove linux-headers
Mahler
  • 739
