On Friday 12th August, When trying to upgrade UbuntuStudio 20.04.4 to 22.04.1 by the network:
  • download was done correctly
  • Upgrading progession was correct.progression
After restarting:
  • the message "mtd device must be supplied (device name is empty)" was displayederror message
  • the login window doesn't appear, it stucks on the Ubuntustudio first display.ubuntustudio
Most of answer on the forum does not match to solve the issue.
What does mean this message "mtd device must be supplied (device name is empty)"?
Does Anyone have a solution to fix it?
Regards
Raerband
raerband
  • 31
I have the same issue, and have done for over a month now. No fixes have been made that eliminate my issue. I run a dual monitor system and the only way to boot for me is either:
  1. Unplug one monitor while booting, and plug it back in once I have logged in, or
  2. Boot via recovery mode, run a dpkg check (which returns zero issues), and then resume normal boot.
GPU: RTX 3080ti GPU Driver: NVIDIA version 515.65.01 OS: Kubuntu 22.04 LTS Kernel: 5.15.0-46-generic 64-bit
There is a fix given here, however this does not solve my issue. If you scroll down, people have given other workarounds too, including making an edit to etc/fstab, although I do not know what I should be changing in there and therefore do not want to accidentally make matters worse for myself.
