So I have an encrypted Ubuntu installation on an M.2 ssd on my desktop that I have been using as my main device, I recently obtained a second SSD and I installed Windows 10 onto it so I could have a duel booted PC. But now I cannot boot into my Ubuntu drive, when I try I get a windows recovery screen. I am thinking that maybe the grub boot loader got corrupted. Would I be able to use the boot recovery tool to reinstall grub on this drive or would I have to manually re-install grub? This is the first time I have dealt with an issue like this so I am not sure what to do if I have to manually re-install grub.
Asked
Active
Viewed 847 times
Bootloaders have the tendency to write to the first disk. So when you want to install another system on another disk the bootloader writes to the first disk anyway.
The solution I use is disconnect the first disk and then do an install. If you have a computer with watercooling and hard tubing that might be a problem though.
What you can do:
1 )Install grub2 again, using the usb stick/device you used to install Ubuntu.
2 ) Install Grub2Win on your Windows installation and make it your default bootloader. And add Ubuntu to the menu/configuration. ( Some hardcore Linux users say that this program is sh#t, but I never had a problem with it.
Joepie Es
- 1,570
