I have a problem with my new ubuntu 22.04 OS; When the boot is started, I see these errors, and the screen will be black:
[    4.817217] usbhid 1-11:1.1: couldn't find an input interrupt endpoint
[    7.498381] mtd device must be supplied (device name is empty)
[    8.677918] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[    8.677921] ucsi_ccg 3-0008: i2c_transfer failed -110
[    8.677927] ucsi_ccg 3-0008: ucsi_ccg_init failed - -110
[    9.705924] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
[   10.710003] snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
[   10.715417] snd_hda_codec_hdmi hdaudioC0D2: No i915 binding for Intel HDMI/DP codec
[   10.718884] snd_hda_intel 0000:00:1f.3: Cannot probe codecs, giving up
[   31.022834] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.022873] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.022889] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.022903] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.355003] audit: type=1107 audit(1660548081.503:130): pid=796 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_signal"  bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.login1.Manager" member="SessionRemoved" name=":1.26" mask="receive" pid=2013 label="snap.skype.skype" peer_pid=812 peer_label="unconfined"
                exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
[   31.355007] audit: type=1420 audit(1660548081.503:131): subj_apparmor=unconfined
[   31.452304] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.452479] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.452580] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.452668] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.490017] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.490076] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.490098] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.490118] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.552243] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.552418] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.552519] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[   31.552606] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
My graphic card is : Nvidia Geforce RTX 2060
Ubuntu kernel version is: 5.15.0-46-generic
ubuntu version is: 22.04
Nvidia driver is?:nvidia-driver-515, (kernel modules provided by linux-modules-nvidia-515-generic-hwe-22.04) How can I solve this problem?
Milano
This happened to me after installing nvidia-cuda-toolkit through apt, with Ubuntu 22.04 + Nvidia GeForce RTX 2060. I eventually repaired the drivers by opening a terminal at the black screen with Ctrl+Alt+F2, then
sudo apt purge nvidia*
sudo apt update
sudo apt full-upgrade
sudo apt install --fix-missing
sudo apt install --fix-broken
sudo apt install linux-headers-$(uname -r)
sudo ubuntu-drivers autoinstall
followed by a reboot, then clicking the gear icon on the login screen and selecting Ubuntu (Xorg), NOT Ubuntu Wayland or anything that involves Wayland, and finally logging in.
If that doesn't work, you can try
sudo apt install xserver-xorg-video-nouveau
Credit to these sources for helping me solve the problem.
RedHand
  • 121
