I want to get access to my Windows Server 2012 R2. There are some errors when I try to connect it.
versions: Ubuntu 22.04.1 LTS Windows Server 2012 R2
remmina-Message: 21:03:03.356: Remmina does not log all output statements. Turn on more verbose output by using "G_MESSAGES_DEBUG=all" as an environment variable.
More info available on the Remmina wiki at:
https://gitlab.com/Remmina/Remmina/-/wikis/Usage/Remmina-debugging
Load modules from /usr/lib/x86_64-linux-gnu/remmina/plugins
Remmina plugin glibsecret (type=Secret) has been registered, but is not yet initialized/activated. The initialization order is 2000.
The glibsecret secret plugin has been initialized and it will be your default secret plugin
(org.remmina.Remmina:142829): GLib-CRITICAL **: 21:03:03.427: g_ascii_strdown: assertion 'str != NULL' failed
(org.remmina.Remmina:142829): GLib-CRITICAL **: 21:03:03.427: g_strrstr: assertion 'haystack != NULL' failed
Warning: Remmina is running with a secrecy plugin, but it cannot connect to a secrecy service.
(org.remmina.Remmina:142829): Gtk-WARNING **: 21:03:03.454: gtk_menu_attach_to_widget(): menu already attached to GtkMenuItem
[21:03:07:138] [142829:142842] [ERROR][com.freerdp.common.settings] - [freerdp_settings_get_bool] Invalid key index 131
[21:03:07:138] [142829:142842] [ERROR][com.freerdp.common.settings] - [freerdp_settings_get_bool] Invalid key index 0
[21:03:08:341] [142829:142842] [ERROR][com.freerdp.core] - transport_connect_tls:freerdp_set_last_error_ex ERRCONNECT_TLS_CONNECT_FAILED [0x00020008]
