I am using Toshiba Portege R835-P70 and function keys work as expected on Windows but they do not on Ubuntu 12.04. For e.g. Fn+F6 and Fn+F7 are supposed to change screen brightness but do not work.
What is the solution for this issue?
I tried adding GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash acpi_backlight=vendor“ to /etc/default/grub, but it introduces an additional problem in that the laptop wakes up to a faintly visible dark screen from hibernation.
I know this is an old issue, but if it is so common, why isn't there a simple solution to it and why isn't it incorporated in latest versions of Ubuntu?
Thanks.
snoop
  • 4,110
  • 41
  • 58
Try this:
open your terminal and type this
sudo gedit /etc/default/grub
and find a line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
and change it to like that. then close the editor and do sudo update-grub and give a restart. check it out now.
Ravexina
  • 57,256
Raja G
  • 105,327
  • 107
  • 262
  • 331
See a solution that worked on my Protege 705-P35 at Toshiba Portege Z830\Z835 [Linux Laptop Wiki]. To make the new script executable, type:
sudo chmod 755 /etc/pm/sleep.d/restore_brightness
Ravexina
  • 57,256
Doug
The following edit to /etc/default/grub helped me:
sudo nano `/etc/default/grub`
and then change the GRUB_CMDLINE_LINUX_DEFAULT to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pcie_aspm=force acpi_backlight=vendor"
Then run update-grub and reboot.
Source
Fabby
  • 35,017
Venem
  • 211
