I'm new just joined up today and installed Ubuntu. When I attempt to install amdgpu-install_22.20.50200-1_all.deb latest AMD driver I get this error:
E: Unable to locate package amdgpu-install_22.20.50200-1_all.deb
The command I'm using:
sudo apt install -f /amdgpu-install_22.20.50200-1_all.deb
Can someone help me out? I get the same error when attempting to install Microsoft Edge. Thank you!
Nmath
  • 12,664
I think you need to define either what you need to install it in terms of where it can be found on the drive or where you need to access it from, so like this
dpkg -i *.deb
Replace *.deb with the path and name of the package you downloaded.
Nmath
  • 12,664
Chimera
Try sudo dpkg -i <path/to/deb>, make sure <path/to/deb> is corrent.
